Believe whatever you want ...Tuner wrote: ↑Wed Aug 01, 2018 1:00 amSemantics or ?? I don't know what you are calling a down-leg, but the straight-leg booster is in all the "390" carbs I have seen, '57 Ford R-1273, R-6895, and later HP versions, all have straight-leg boosters. The '57 312 carb is essentially the same casting as the 6895, venturi shape is identical. Later HP versions have the radiused venturi entrance shape, early units have an essentially straight funnel shape venturi inducer, like an R-1850. I trust we are on the same page, a down-leg booster is the type found in original R-3310 and R-4779, 4780,4781, etc.Walter R. Malik wrote: ↑Tue Jul 31, 2018 10:40 pmThe particular carburetor I was referring to was the R6895 "double pumper" from the early 80's; (the one which had the down-leg but, straight through boosters). Not the 1957 "vacuum secondary" R1847.Walter R. Malik wrote: ↑Tue Jul 31, 2018 9:03 am
At 20.4 inches of water depression it will wet flow right around 390. Dry flow will of course be more.
The carb R7411 with regular down-leg boosters came later in the 90's.
Then even later came the HP carbs R80507, progressing with dash numbers of the same to follow.
You are not correct with information here and you obviously haven't ever had one in your hands or simply don't remember ... down-leg boosters with the booster venturi bored to straight through were in the original NASCAR 390 "double pumper" carburetors from Holley.
There were not even such a thing as any Holley "double pumper" carburetors until 1969.
