Did you get your mords wixed? You do mean the booster on the far right, eh?Warp Speed wrote: ↑Wed Aug 01, 2018 1:21 pm The HP 390 carbs came in the scene in the mid 90s. Before that, the standard issue 390 that was used in the GN series, both using a straight leg booster, as tuner posted in his pic, to the far left.
That how I recall the late 80s through the 90s anyway?
Holley 390 nascar carb flow. ( mechanical throttles )
Re: Holley 390 nascar carb flow. ( mechanical throttles )
Yes, I sure did!Tuner wrote: ↑Thu Aug 02, 2018 1:56 amDid you get your mords wixed? You do mean the booster on the far right, eh?Warp Speed wrote: ↑Wed Aug 01, 2018 1:21 pm The HP 390 carbs came in the scene in the mid 90s. Before that, the standard issue 390 that was used in the GN series, both using a straight leg booster, as tuner posted in his pic, to the far left.
Far right! Lol
