How do the engine masters competitors get their engines to pull from 2300 at wide open throttle?joe 90 wrote: ↑Sat Jul 28, 2018 10:28 pm I've always done my road tuning that way too. 2nd gear, walking speed, floor it until getting to the red line.....take datalog.
The rate of change of RPM follows the torque curve, if it misfires or hesitates, it's not good enough....fix it, try again.
What you notice often, youtube is a great example, dyno runs start at 3500RPM or so.......that's because the waterbrake can't hold it at lower RPMs....it's under rated.
Can't floor it from 700 RPM idle
Re: Can't floor it from 700 RPM idle
Of course not. More tip-in fuel more likely.
http://www.fastchip.com/
SS/JA 4156
SS/JA 4156
Footbrake racing.. although it won't be from a true idle, but a stumble means a loss.
gmrocket wrote: ↑Sat Jul 28, 2018 11:48 pmHow do the engine masters competitors get their engines to pull from 2300 at wide open throttle?joe 90 wrote: ↑Sat Jul 28, 2018 10:28 pm I've always done my road tuning that way too. 2nd gear, walking speed, floor it until getting to the red line.....take datalog.
Crickets from mr know it all
Just so I am getting this straight, you have not been able to floor it from an idle since 2002? Now, by some miracle and engineering stroke of genius that just occured either by drugs, alcohol, or divine intervention you can floor it at 700 rpm and it takes off like a raped ape? I have personally never witnessed just how fast a raped ape can accelerate but I would think it would be similar to a bat out of hell, not that I've seen one of those. However when you say "wild" I take it that you are tickled and I hope I have your enthusiasm if I make it to your age. Another clue is "blow thru". Anytime the word "blow" is used in any connotation it quickens my pulse. Example.."I think the engine's gonna blow..or.. I eat so much chili I'm gonna blow.. or.. a good looking gal suggest a blow....oldhead wrote: ↑Fri Jul 27, 2018 9:30 am Can't floor it from 700 RPM idle, Thats my 950 holley blow thru,Its from back in 2002 from one of the oldest shops. They said you must come off higher like 2000. How would you fix that ???? I did in such a way you won't believe. It real strong. Even put the T400 in second and smack it,Wild Oldhead
Please tell us the fix. Thanks for this breath of fresh air thread.
Surely "blow through" is a red herring? At 700 rpm, zero boost, problem would still be there, even if you disconnect the boost ducting to the carb top?
Sir, consider yourself nominated for this award.Old School wrote: ↑Mon Jul 30, 2018 12:24 amJust so I am getting this straight, you have not been able to floor it from an idle since 2002? Now, by some miracle and engineering stroke of genius that just occured either by drugs, alcohol, or divine intervention you can floor it at 700 rpm and it takes off like a raped ape? I have personally never witnessed just how fast a raped ape can accelerate but I would think it would be similar to a bat out of hell, not that I've seen one of those. However when you say "wild" I take it that you are tickled and I hope I have your enthusiasm if I make it to your age. Another clue is "blow thru". Anytime the word "blow" is used in any connotation it quickens my pulse. Example.."I think the engine's gonna blow..or.. I eat so much chili I'm gonna blow.. or.. a good looking gal suggest a blow....oldhead wrote: ↑Fri Jul 27, 2018 9:30 am Can't floor it from 700 RPM idle, Thats my 950 holley blow thru,Its from back in 2002 from one of the oldest shops. They said you must come off higher like 2000. How would you fix that ???? I did in such a way you won't believe. It real strong. Even put the T400 in second and smack it,Wild Oldhead
However, to receive your award, you will need to forward $9.00 (US) + $10.25 shipping to Amazon.com
https://www.amazon.com/Customizable-Hor ... ZDXTKH6FCB
wut? Now they are selling my award? fook amazon
I liked this comment. "I have personally never witnessed just how fast a raped ape can accelerate but I would think it would be similar to a bat out of hell"
-Carl
-Carl
It was not my intention to come off as an ass. It was meant as a light hearted attempt to get Oldhead to tell us the fix. My apology to Oldhead and anyone else that I may have offended.Tuner wrote: ↑Mon Jul 30, 2018 11:57 amSir, consider yourself nominated for this award.Old School wrote: ↑Mon Jul 30, 2018 12:24 amJust so I am getting this straight, you have not been able to floor it from an idle since 2002? Now, by some miracle and engineering stroke of genius that just occured either by drugs, alcohol, or divine intervention you can floor it at 700 rpm and it takes off like a raped ape? I have personally never witnessed just how fast a raped ape can accelerate but I would think it would be similar to a bat out of hell, not that I've seen one of those. However when you say "wild" I take it that you are tickled and I hope I have your enthusiasm if I make it to your age. Another clue is "blow thru". Anytime the word "blow" is used in any connotation it quickens my pulse. Example.."I think the engine's gonna blow..or.. I eat so much chili I'm gonna blow.. or.. a good looking gal suggest a blow....oldhead wrote: ↑Fri Jul 27, 2018 9:30 am Can't floor it from 700 RPM idle, Thats my 950 holley blow thru,Its from back in 2002 from one of the oldest shops. They said you must come off higher like 2000. How would you fix that ???? I did in such a way you won't believe. It real strong. Even put the T400 in second and smack it,Wild Oldhead
He did tell us the fix, but because he did it in another thread he nominated himself for one of these awards too. viewtopic.php?f=1&t=54127&p=755862#p755862Old School wrote: ↑Mon Jul 30, 2018 12:26 pmIt was not my intention to come off as an ass. It was meant as a light hearted attempt to get Oldhead to tell us the fix. My apology to Oldhead and anyone else that I may have offended.Tuner wrote: ↑Mon Jul 30, 2018 11:57 amSir, consider yourself nominated for this award.Old School wrote: ↑Mon Jul 30, 2018 12:24 am
He did tell us the fix, but because he put it in another thread he nominated himself for one of those awards too. viewtopic.php?f=1&t=54127&p=755862#p755862
CHECK OUT THE ANSWER ON "CAN FLOOR IT FROM 700 IDLE"
Quicker then most
