Camshaft data
Camshaft data
Does anyone have some camshaft data (lift vs. degree) they can share with me? I need something comparable to what you would put in Cam Doctor or Cam Analyzer? Not looking for anyone's trick cam data, just need something to feed into an Excel program I have written to calculate valve curtain area. Some old smallblock Chevy data would be great. Thanks.
Re: Camshaft data
Roller using 0.750 wheel diameter and 1.020 base circle diameter. Have fun.
.00000000
.00000035
.00000536
.00002622
.00007987
.00018743
.00037253
.00065968
.00107270
.00163330
.00235989
.00326670
.00436316
.00565384
.00713881
.00881458
.01067567
.01271691
.01493652
.01734000
.01994411
.02277223
.02584631
.02918536
.03280506
.03671752
.04093124
.04545114
.05027876
.05541244
.06084760
.06657700
.07259108
.07887821
.08542500
.09221657
.09923683
.10646870
.11389435
.12149541
.12925313
.13714858
.14516279
.15327685
.16147206
.16973001
.17803267
.18636245
.19470228
.20303564
.21134661
.21961990
.22784086
.23599551
.24407056
.25205339
.25993208
.26769537
.27533269
.28283413
.29019042
.29739294
.30443367
.31130521
.31800071
.32451390
.33083903
.33697085
.34290461
.34863601
.35416117
.35947663
.36457932
.36946649
.37413576
.37858503
.38281247
.38681654
.39059589
.39414941
.39747616
.40057538
.40344643
.40608882
.40850216
.41068615
.41264057
.41436525
.41586010
.41712503
.41816001
.41896500
.41954000
.41988500
.42000000
.41988500
.41954000
.41896500
.41816001
.41712503
.41586010
.41436525
.41264057
.41068615
.40850216
.40608882
.40344643
.40057538
.39747616
.39414941
.39059589
.38681654
.38281247
.37858503
.37413576
.36946649
.36457932
.35947663
.35416117
.34863601
.34290461
.33697085
.33083903
.32451390
.31800071
.31130521
.30443367
.29739294
.29019042
.28283413
.27533269
.26769537
.25993208
.25205339
.24407056
.23599551
.22784086
.21961990
.21134661
.20303564
.19470228
.18636245
.17803267
.16973001
.16147206
.15327685
.14516279
.13714858
.12925313
.12149541
.11389435
.10646870
.09923683
.09221657
.08542500
.07887821
.07259108
.06657700
.06084760
.05541244
.05027876
.04545114
.04093124
.03671752
.03280506
.02918536
.02584631
.02277223
.01994411
.01734000
.01493652
.01271691
.01067567
.00881458
.00713881
.00565384
.00436316
.00326670
.00235989
.00163330
.00107270
.00065968
.00037253
.00018743
.00007987
.00002622
.00000536
.00000035
.00000000
.00000000
.00000035
.00000536
.00002622
.00007987
.00018743
.00037253
.00065968
.00107270
.00163330
.00235989
.00326670
.00436316
.00565384
.00713881
.00881458
.01067567
.01271691
.01493652
.01734000
.01994411
.02277223
.02584631
.02918536
.03280506
.03671752
.04093124
.04545114
.05027876
.05541244
.06084760
.06657700
.07259108
.07887821
.08542500
.09221657
.09923683
.10646870
.11389435
.12149541
.12925313
.13714858
.14516279
.15327685
.16147206
.16973001
.17803267
.18636245
.19470228
.20303564
.21134661
.21961990
.22784086
.23599551
.24407056
.25205339
.25993208
.26769537
.27533269
.28283413
.29019042
.29739294
.30443367
.31130521
.31800071
.32451390
.33083903
.33697085
.34290461
.34863601
.35416117
.35947663
.36457932
.36946649
.37413576
.37858503
.38281247
.38681654
.39059589
.39414941
.39747616
.40057538
.40344643
.40608882
.40850216
.41068615
.41264057
.41436525
.41586010
.41712503
.41816001
.41896500
.41954000
.41988500
.42000000
.41988500
.41954000
.41896500
.41816001
.41712503
.41586010
.41436525
.41264057
.41068615
.40850216
.40608882
.40344643
.40057538
.39747616
.39414941
.39059589
.38681654
.38281247
.37858503
.37413576
.36946649
.36457932
.35947663
.35416117
.34863601
.34290461
.33697085
.33083903
.32451390
.31800071
.31130521
.30443367
.29739294
.29019042
.28283413
.27533269
.26769537
.25993208
.25205339
.24407056
.23599551
.22784086
.21961990
.21134661
.20303564
.19470228
.18636245
.17803267
.16973001
.16147206
.15327685
.14516279
.13714858
.12925313
.12149541
.11389435
.10646870
.09923683
.09221657
.08542500
.07887821
.07259108
.06657700
.06084760
.05541244
.05027876
.04545114
.04093124
.03671752
.03280506
.02918536
.02584631
.02277223
.01994411
.01734000
.01493652
.01271691
.01067567
.00881458
.00713881
.00565384
.00436316
.00326670
.00235989
.00163330
.00107270
.00065968
.00037253
.00018743
.00007987
.00002622
.00000536
.00000035
.00000000
Re: Camshaft data
What are your increments - cam or crank degrees? Valve lift or lobe Lift?ingram wrote: ↑Thu Jul 26, 2018 3:56 pm Roller using 0.750 wheel diameter and 1.020 base circle diameter. Have fun.
.00000000
.00000035
.00000536
.00002622
.00007987
.00018743
.00037253
.00065968
.00107270
.00163330
.00235989
.00326670
.00436316
.00565384
.00713881
.00881458
.01067567
.01271691
.01493652
.01734000
.01994411
.02277223
.02584631
.02918536
.03280506
.03671752
.04093124
.04545114
.05027876
.05541244
.06084760
.06657700
.07259108
.07887821
.08542500
.09221657
.09923683
.10646870
.11389435
.12149541
.12925313
.13714858
.14516279
.15327685
.16147206
.16973001
.17803267
.18636245
.19470228
.20303564
.21134661
.21961990
.22784086
.23599551
.24407056
.25205339
.25993208
.26769537
.27533269
.28283413
.29019042
.29739294
.30443367
.31130521
.31800071
.32451390
.33083903
.33697085
.34290461
.34863601
.35416117
.35947663
Thanks.
Re: Camshaft data
Sorry, when I think of cam profile lift tables, everything is at the lobe. One degree rotation at the lobe with the lift at the tappet that the profile is being designed for.
Re: Camshaft data
You can graph that data and stretch it horizontally (change the increment size) or vertically (multiply the lift by a factor) to make whatever duration and lift you want.
- Stan Weiss
Re: Camshaft data
Also you to make sure once you have you intake and exhaust lobes you have coded a way to adjust LSA as well as advance or retard the cam
Stan
Stan
