STD.1x FE Rod bearings
ProPower engines
Post by ProPower engines »
Does anyone know where a set of 1X std rod bearings can be had for a ford 427 FE series crank??
I have a crank that is on the high side of STD and need a 1X set of rod bearings to avoid the need to grind the crank .010US on the rod throws.
I have an FM part number 7170CH1X for .001 extra clearance.
Any leads are greatly appreciated
Dave
ProPower engines
Re: STD.1x FE Rod bearings
Thanks for the tip they should be here next tuesday.
Thanks again for the lead =D>
Dave
