Pontiac ram air 5
Re: Pontiac ram air 5
Google McCarty RAV Pontiac and there are builds on their website.
NHRA SS/G
1970 AMC AMX - 390 4-speed
Would somebody please post up the bore and stroke of all of the old Pontiac engines they were trying to run back then.
I'm just not sure about the 303 and 366 engines, but do know a bit about the 326/336, 350, 400, 421, and 455 ones.
I got to watch, "Farmer", run one time as a kid back in HS at Kahoka, MO. I think he was running a new '63 or '64 white Tempest S/W. Arnie's "Grocery-Getter", car??
There were a pair of Crosley S/W's, a blue one and a bright yellow one that were a real hoot! The yellow one was named the, "Blown Banana"!!
Back about '64??
Back about '64??
I believe the 303 was 4.120 and 2.84 and they were done with a 9.2 deck and a 10.2 deck.The 366 is 4.155 and 3.375 and was only a 10.2 deck.Tom
Here is a thread of the 366 street engine build on Big Joes dyno.Tom
http://forums.maxperformanceinc.com/for ... p?t=755522
Re: Pontiac ram air V
1969 Royal Bobcat ram air V gto, in 1969 at palm beach dragway it ran 12.85 @ 109.50, 400 cuin, 11 t0 1, solid cam, jr heades, 4.33 gears, g70-14 tires, 4 speed, from 1987 car review musclecar annual.
BORN RIGHT THE FIRST TIME
New V offerings have been avail for 10 years. Haven't yet seen any solid N/A track results.
Was dyno of a 609 where BES relocated the pushrod out of the port.
Mike R
Although I live and bleed RA V I dont believe a port with the pushrod in the center will ever be as efficient as one without.JMHO,Tom
All you have to do is compensate for the area restriction it presents by adding more port area !
I blew out the dust from my 1972 archive's and here's what I found.
