edelbbock carbs
redgoldstein
edelbbock carbs
Post by redgoldstein »
best mods for eddy carbs for 454 471 blower street motor thanks
user-30257
Re: edelbbock carbs
Post by user-30257 »
redgoldstein wrote: Sun Jul 15, 2018 4:50 pm best mods for eddy carbs for 454 471 blower street motor thanks
Jets and rods. Put it on a chassis dyno get it close .
Frankshaft
Re: edelbbock carbs
Post by Frankshaft »
Remove and replace with Holley's.
Steve.k
Re: edelbbock carbs
Post by Steve.k »
Frankshaft wrote: Sun Jul 15, 2018 5:41 pm Remove and replace with Holley's.
Second that motion. Someone may get them to work. Ive had zero luck.
Mark O'Neal
Re: edelbbock carbs
Post by Mark O'Neal »
Where the "like" button?
BigBlockMopar
Momentary Specialist
Re: edelbrock carbs
Post by BigBlockMopar »
Well-designed carbs don't have gaskets below fuel level which could dry out and leak over time with occassional use...
* please wait until I have put my flame-suit on * ... this might get rough [-o<
F-BIRD'88
Re: edelbbock carbs
Post by F-BIRD'88 »
Use a pair of them on a dual carb adapter.
The blower shop sells it.
Jets and rods simple tuning it.
2x750. 2x 650. ...
Frankshaft
Re: edelbrock carbs
bigblockmopar wrote: Sun Jul 15, 2018 6:31 pm Well-designed carbs don't have gaskets below fuel level which could dry out and leak over time with occassional use...
Do you frequent any race tracks? Circle, drag, road race. Next time you go, just take a quick mental note on how many guys have Holley carbs, or a derivative of one. And then see if you can even find an Edelbrock carb. Pretty much sums it up.
andyf
Re: edelbbock carbs
Post by andyf »
Which carbs do you have? For an engine like that I'd probably use dual 500 cfm Edelbrock carbs. The dual 500 cfm setup will be good for most any street driven engine. The Edelbrock carbs are easy to setup and they have an excellent idle circuit that really smooths the engine out on the street.
Andy F.
AR Engineering
tjs44
Re: edelbbock carbs
Post by tjs44 »
I run a lot of dual carb setups on the street.My choice is ORIGINAL Carter AFBs.JMO,a pair of 500s are way too small for a 454 let alone with the blower.Factory 409s came with a pair of 625 AFBs.I forsure would not go smaller that that.I run a pair of 750 factory AFBs on a 434 N/A with no issue at all.FWIW,Tom
Walter R. Malik
Re: edelbbock carbs
Post by Walter R. Malik »
A 4-71 blower is just to small on any 454 size engine for any appreciable boost other than playing around on a "cruiser" at 2 pounds or so; and then it is gonna make a LOT of heat and the compression ratio needs to be made even lower than expected.
In my opinion, Using dual 4 barrel carbs is certainly not going to be of any benefit and just a waste.
Frankshaft
Re: edelbbock carbs
Walter R. Malik wrote: Sun Jul 15, 2018 7:53 pm
Good point about the tiny blower.
F-BIRD'88
Re: edelbbock carbs
Post by F-BIRD'88 »
The ignorance and thus mis information is really thick here.
The 4-71 on a basic 454 is more than capable of a real deal 650+++hp
on pump gas. Do not choke off with a small carb or small carbs.
Use 2x650's minimum. 2x750's is JUST right.
Drive the 4-71 blower at a 1.3:1 to 1.6:1 drive ratio on the 454.
this is no where near excessive.
Use a ready available off the shelf cam such as a Comp XE284H-10 hyd flat tappet
or A comp XR 286R-10 solid street roller cam.
These are both great on street blower 454's
The edelbrocks are very easy to set up for roots supercharging.
The only real critical thing is the power piston spring choice
Use the 10.5" vacuum rated springs in the carbs.
Carbs will need rejetting.
Edelbrock carbs do not like big fuel pressure 5.5psi at idle is great.
Yes you want a low cr for pump gas. 7.5 to 8.5:1
Home ported 049 or 781 oval port heads with larger 2.19x1.88 valves are fine. Use with flat top forged pistons for a street blower friendly low cr.
It will make big power and plenty boost 7psi is plenty on pump gas.
F-BIRD'88
Re: edelbbock carbs
Post by F-BIRD'88 »
A blower drive ratio of right about 1.42:1 to 1.50:1 should be smack dead on for 7psi boost on a 4-71 street blown 454.
It will make BIG reliable street power at this drive ratio BUT DO NOT choke it off with a single carb or small carbs. A roots blown motor has to EAT.
if you add a water/methanol injection system you can use a lot more boost and make even more power by driving the 4-71 blower a bit faster,
(1.6:1 to 1.8:1 drive ratio)
Well in excess of 700HP. Do not choke it with small carbs.
It needs 2 big carbs for this. 2x eddy 750's are fine.
Ya a 8-71 makes more ultimate power.
This is all about getting great power from a 4-71 on a 454.
Geoff2
Re: edelbbock carbs
Post by Geoff2 »
Agree, use the Edel or original AFBs. Keep the Holleys for door stops....
