Stock class heads. No porting
Steve.k
Re: Stock class heads. No porting
Post by Steve.k »
Could be. I'll weigh in shop. And post weight.
mag2555
Post by mag2555 »
Should have posted" to see how the velocity numbers change", that being said I have bolted on a Manifold to a head and picked up flow numbers in a given small valve lift range and that does constitute a velocity gain at that lift non the less!
Steve.k
Post by Steve.k »
I weighed the valves this morning. Intake is 125g and exh 116. Not sure why geoff had those on there. However he did do another set of heads for me that had the old trw ti valves.
midnightbluS10
Post by midnightbluS10 »
I believe ls7 titanium intake valves are around 77g so that would make sense that the weights listed were for Ti. I only used that, as an example because it was the only one I'm fairly sure of off the top of my head.
JC -
russxr67
Post by russxr67 »
Manley valves are typically that weight on a Cleveland, the Ferrea are a damn sight heavier but flow better.
