Cold valve lash with Jones solid roller
redliner
Post by redliner »
What is the baseline rule of thumb for setting the valve lash cold on my aluminum headed sbc? The hot lash for the Jones solid roller is in. .016 ex. .020.
blykins
Re: Cold valve lash with Jones solid roller
Post by blykins »
I don't do a lot of Chevy stuff, but my cast iron block/aluminum headed SBF's and FE's want .006" tighter cold lash. All-aluminum is usually .015" tighter cold.
Lykins Motorsports
brent@lykinsmotorsports.com
www.lykinsmotorsports.com
www.customfordcams.com
redliner
Post by redliner »
blykins wrote: Wed Jul 11, 2018 9:22 am I don't do a lot of Chevy stuff, but my cast iron block/aluminum headed SBF's and FE's want .006" tighter cold lash. All-aluminum is usually .015" tighter cold.
Thanks! It seems I was told a couple years ago to go .004 tighter then the hot setting which is printed on the cam card.Also, it seems .008 rings a bell....
77cruiser
Post by 77cruiser »
.004-.005 worked for me.
Jim
CamKing
Post by CamKing »
Go .006"-008" tighter for break-in.
With the engine at running temp, shut it off, and set the valves on one cylinder to the Hot lash on the card.
Let the engine fully cool down.
Measure the lash on that cylinder that you set hot.
That will be the cold lash setting to use on all the cylinders.
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
redliner
Post by redliner »
CamKing wrote: Wed Jul 11, 2018 10:30 am Go .006"-008" tighter for break-in.
Got it! Thanks!
