427 Ford Rod Bolts
My427stang
Re: 427 Ford Rod Bolts
Post by My427stang » Sat Jul 14, 2018 6:00 pm
PFC1 wrote:
Fri Jul 13, 2018 9:53 pm
Don't remember the size for sure but there is a metric (seems like 15mm) that fits that nut real well.
Absolutely correct
19/32 = 15.08 mm, I have both sockets, but I am usually searching the drawer for the loose 19/32 so I often grab the 15mm and it's fit every one yet. All Snap-on, but built with the proper .08 mm (0.003 inches) FE rod bolt slack ;)
70 Mustang, 489 FE, TKO-600, Massflo SEFI, 4.11s
71 F100 SB 4x4, 445 FE, hot rod 4x4
CGT
Post by CGT » Sun Jul 15, 2018 8:45 pm
15 would be really close. 19/32 .594 15.08mm. Might depend who's brand 15mm
"If you pick up a starving dog and make him prosperous, He will not bite you. This is the principal difference between a dog and a man"
bill jones
Post by bill jones » Mon Jul 16, 2018 1:11 pm
---I just remembered that I have a set of 16 new Ford rod bolts and 15 nuts as I have described here.
---Probably have had these laying around for something like 40 years.
---when I got the new bolts I machined each end so I could use a micrometer to check the stretch.
---for some reason I ended up with 13 used nuts and 2 new nuts.
---I have also lightly polished around the outside of the rod bolt heads to remove some not so perfect looking skin of those areas.
---for sure the used rod nuts have only been installed to where there is one side showing the shiny friction surface--other side has never been torqued against.
---these photos are what they look like today.
$100---16 new Ford 428 large diameter rod bolts that use 13/32” nuts (15mm socket)
---part number is C2AZ-6214-B
---both ends are machined to allow checking for stretch with a micrometer
---OD of threads measure .3990”---OD of shank is .405”--has a .371” OD x .398” long stretch area
$ 40---only have 15 total 13/32 nuts (all nuts require a 15mm socket) for the large Ford rod bolts.
---13 are pristine used 13/32” hex nuts with the one used side lightly polished flat.
----2 are brand new 13/32 nuts Ford part #COME-6212-A
---ID of the nuts measure .365”---the hex head of the nut measures .588”---requires a 15MM socket
Post by MadBill » Mon Jul 16, 2018 5:46 pm
I wonder if Ford packaged them in boxes of ten under the pragmatic assumption that one or two would roll off under the bench or if it's just another example of the 'hot dog conundrum', wherein wieners come in ten-packs but buns in eight... :-k
ProPower engines
Post by ProPower engines » Tue Jul 17, 2018 1:47 am
Thanks Bill
I got what I hope ARP says are an exact replacement for the OE bolts buy some how I suspect they are just the same bolt with a 3/8"NF flanged nut but the larger hex nut but I will see when they get here tomorrow.
After I check these new bolts if there is any doubt about fit I will contact you for the OE bolts you have on hand.
And many Thanks for looking and rounding them up But in the interim don't pack them away just in case. Depending on what I recieve from ARP I may have to call you.
Dave
