On my particular dual quad intake at WOT each runner has a direct path to a carb bore/venturi but there is a smaller plenum connector opening that connects them all for part throttle use when cruising on one carbs primaries.
So at WOT should a pair of carbs be used which each have the 4 venturi and throttle bores the same size for even flow to all cylinders?
Another intake manifold / carb size question..
