ls7 head sealing issue
slo-svt
Post by slo-svt »
My ls7 blew a head gasket last night (I hope). Stock bottom end 13.3:1 static compression, msd atomic intake, 1 7/8 headers, cometic .036 gaskets, stock head bolts, 250/262 cam, e85. Ran it all last year without issues. I recently switched to e85 and this is my third outing with the car since then. I believe the stock head bolts to be the cause. We had a cold front come through yesterday and the da dropped from 3000+ to 1900. I am obviously going to replace head gaskets and get aftermarket bolts or studs. What is everyone's opinion on bolts vs studs? I cant see my combination requiring studs but I also didn't think I would have issues with the factory bolts. With that said this isn't the first time I have seen an ls engine have cylinder head sealing issues after converting to e85. Anyone have experience with the speed master studs? I'm leaning towards the arp bolts just because of the price point but would value others opinions.
Pure logical thinking cannot yield us any knowledge of the empirical world; all knowledge of reality starts from experience and ends in it.
Albert Einstein
pamotorman
Re: ls7 head sealing issue
Post by pamotorman »
did you test the E-85 to make sure of the % of ethanol in the product ??
slo-svt
Post by slo-svt »
It has a composition sensor. It has been 80-85 percent since I started using a couple week ago.
Albert Einstein
CGT
Post by CGT »
slo-svt wrote: Fri Jul 06, 2018 2:55 pmMy ls7
So is the equivalent of saying "My Duramax"? Does "Your LS7" belong to a car, street rod, hover boat?
slo-svt wrote: Fri Jul 06, 2018 2:55 pm We had a cold front come through yesterday and the da dropped from 3000+ to 1900
Is this an attempt at deflecting what sounds like improper torque procedure or prep on the weather?
slo-svt wrote: Fri Jul 06, 2018 2:55 pm Anyone have experience with the speed master studs?
So you have an all aluminum, titanium outfitted 7 litre engine, and your inquiring on some ching chang chong fasteners? I'd go for it.
Post by MadBill »
I'd go with name-brand studs.
user-23911
Post by user-23911 »
Probably too much ignition timing that did it. A common problem with E85.
Try retorquing the heads first.
There's probably at least one bolt loose.
You'll find it by going through one bolt at a time, put a paint mark on it, crack it loose, retorque to spec and take a note of where the paint mark ends up compared to where it started.
That's how you find out.
But it's far easier to just blame the parts.
32vape
Post by 32vape »
How much spark advance are you running between 5000-6000 rpm with the e85?
slo-svt
Post by slo-svt »
CGT wrote: Fri Jul 06, 2018 4:50 pm
You should know that "my ls7" is slang used by non other than a jort wearing corvette owner..
It was a reference to this day being likely the highest cylinder pressure the engine has seen since it was put on e85. I'm sure the community speedtalk troll knows this.
I was a question of experience with the fasteners it was clear that i was leaning towards arp bolts with the belief that the studs are overkill on my engine.
Albert Einstein
slo-svt
Post by slo-svt »
joe 90 wrote: Sat Jul 07, 2018 1:26 am Probably too much ignition timing that did it. A common problem with E85.
Retorqueing tty bolts doesn't seem like it would give me any kind of an accurate result. The bolts are designed to stretch and will make them all falsey appear loose using your method when retorqued. The manufacturer makes it clear that they are to be discarded after being torqued.
Albert Einstein
slo-svt
Post by slo-svt »
32vape wrote: Sat Jul 07, 2018 1:48 am How much spark advance are you running between 5000-6000 rpm with the e85?
The ecm adds 4 degrees for true 85% ethanol and interpolates down to 2 at 50% ethanol. It had 83% in it when it happened when it goes into power enrichment. Due to the way cylinder airmass is calculated my engine typically sees over 1.0 at wot. That will give you and idea where it was on the timing table.
Albert Einstein
CGT
Post by CGT »
So the motor can't see over 30° correct? That doesn't seem excessive to me by any means. But, taking head gaskets out of a NA LS isn't really typical either. Have you considered that it may not be a head gasket? I'm to the point that I'm done with the stock head bolts in anything but stock or slightly warmed over $HIT.
Jorts? I saw a black Z06 the other night blowing white smoke going down the interstate, it had an "anus destroyer" bumper sticker on it and was being driven by a millennial wearing a romper. Was that you? You a St. Louis guy by chance? :oops:
user-23911
slo-svt wrote: Sat Jul 07, 2018 9:10 am
In which case you'll never learn anything new.
In-Tech
Vendor
Post by In-Tech »
There are other tables to consider besides the high octane timing table you posted.
These are not from your calibration, just noting it for things to consider besides the main, high and low octane, spark tables. You might be commanding more timing than you realize. #-o
Code: Select all
	P.E. Spark Advance Correction Vs. Eq. Ratio Vs. RPM
  Eq. Ratio                                                    RPM
               800  1200  1600  2000  2400  2800  3200  3600  4000  4400  4800  5200  5600  6000  6400  6800  7200
    1.00       0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0
    1.05       0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0
    1.10       0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   1.0   0.0   0.0   0.0   0.0
    1.15       0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   1.0   1.5   2.0   2.5   2.0   1.5   1.5
    1.20       0.0   0.0   0.0  -1.0  -1.0  -1.0  -1.0  -1.5  -2.0   0.5   3.0   3.5   4.0   5.0   4.5   3.5   3.5
    1.25       0.0   0.5   0.0  -1.0  -1.0  -1.0  -1.0  -1.5  -2.0   0.5   3.0   3.5   4.0   5.0   4.5   3.5   3.5
    1.30       0.0   0.5   0.0  -1.0  -1.0  -1.0  -1.0  -1.5  -2.0   0.5   3.0   3.5   4.0   5.0   4.5   3.5   3.5
    1.35       0.0   0.5   0.0  -1.0  -1.0  -1.0  -1.0  -1.5  -2.0   0.5   3.0   3.5   4.0   5.0   4.5   3.5   3.5
    1.40       0.0   0.5   0.0  -1.0  -1.0  -1.0  -1.0  -1.5  -2.0   0.5   3.0   3.5   4.0   5.0   4.5   3.5   3.5
    1.45       0.0   0.5   0.0  -1.0  -1.0  -1.0  -1.0  -1.5  -2.0   0.5   3.0   3.5   4.0   5.0   4.5   3.5   3.5
    1.50       0.0   0.5   0.0  -1.0  -1.0  -1.0  -1.0  -1.5  -2.0   0.5   3.0   3.5   4.0   5.0   4.5   3.5   3.5
Code: Select all
	ECT Spark Advance Correction Vs. Load Vs. Coolant Temp.
  gm/cyl.                                                  Deg. C
             -20   -10   0     10    20    30    40    50    60    70    80    90    100   110   120   130   140
    0.08     0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0
    0.12     0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0
    0.16     0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0
    0.20     0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0  -0.5  -1.0  -3.0  -3.0
    0.24     0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0  -0.5  -1.0  -2.0  -4.0  -4.0
    0.28     0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0  -1.0  -1.5  -3.0  -5.0  -5.0
    0.32     0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0  -1.0  -2.0  -4.0  -6.0  -6.0
    0.36     0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0  -1.5  -3.0  -5.0  -7.0  -7.0
    0.40     0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0  -2.0  -5.0  -6.0  -8.0  -8.0
    0.44     0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0   0.0  -2.0  -5.0  -7.0  -8.0  -8.0
    0.48     1.5   1.0   1.0   1.0   0.5   0.5   0.5   0.5   0.5   0.0   0.0   0.0  -3.0  -5.0  -7.0  -9.0  -9.0
    0.52     4.0   3.0   2.0   2.0   2.0   1.5   1.5   1.0   0.5   0.5   0.0   0.0  -3.0  -5.0  -7.0  -9.0  -9.0
    0.56     7.0   5.0   4.0   3.5   3.5   3.0   2.5   2.0   1.0   0.5   0.0   0.0  -3.0  -5.0  -7.0  -9.0  -9.0
    0.60     9.5   7.0   5.5   5.0   4.5   4.0   3.5   2.5   1.5   0.5   0.0   0.0  -3.0  -5.0  -7.0  -9.0  -9.0
    0.64    11.5   8.0   6.5   6.0   5.5   5.0   4.0   3.0   2.0   0.5   0.0   0.0  -3.0  -5.0  -7.0  -9.0  -9.0
    0.68    13.5   9.5   8.0   7.0   6.5   6.0   5.0   3.5   2.5   1.0   0.0   0.0  -3.0  -5.5  -7.0  -9.0  -9.0
    0.72    15.0  10.5   9.0   8.0   7.5   6.5   5.5   4.0   2.5   1.0   0.0   0.0  -3.0  -6.0  -7.0  -9.0  -9.0
    0.76    16.5  12.0  10.0   9.0   8.0   7.0   6.0   4.5   3.0   1.0   0.0   0.0  -3.0  -6.0  -7.0  -9.0  -9.0
    0.80    18.0  13.0  11.0  10.0   9.0   8.0   6.5   5.0   3.0   1.0   0.0   0.0  -3.0  -6.0  -7.0  -9.0  -9.0
    0.84    18.0  13.0  11.0  10.0   9.0   8.0   6.5   5.0   3.0   1.0   0.0   0.0  -3.0  -6.0  -7.0  -9.0  -9.0
    0.88    18.0  13.0  11.0  10.0   9.0   8.0   6.5   5.0   3.0   1.0   0.0   0.0  -3.0  -6.0  -7.0  -9.0  -9.0
    0.92    18.0  13.0  11.0  10.0   9.0   8.0   6.5   5.0   3.0   1.0   0.0   0.0  -3.0  -6.0  -7.0  -9.0  -9.0
    0.96    18.0  13.0  11.0  10.0   9.0   8.0   6.5   5.0   3.0   1.0   0.0   0.0  -3.0  -6.0  -7.0  -9.0  -9.0
    1.00    18.0  13.0  11.0  10.0   9.0   8.0   6.5   5.0   3.0   1.0   0.0   0.0  -3.0  -6.0  -7.0  -9.0  -9.0
    1.04    18.0  13.0  11.0  10.0   9.0   8.0   6.5   5.0   3.0   1.0   0.0   0.0  -3.0  -6.0  -7.0  -9.0  -9.0
    1.08    18.0  13.0  11.0  10.0   9.0   8.0   6.5   5.0   3.0   1.0   0.0   0.0  -3.0  -6.0  -7.0  -9.0  -9.0
    1.12    18.0  13.0  11.0  10.0   9.0   8.0   6.5   5.0   3.0   1.0   0.0   0.0  -3.0  -6.0  -7.0  -9.0  -9.0
    1.16    18.0  13.0  11.0  10.0   9.0   8.0   6.5   5.0   3.0   1.0   0.0   0.0  -3.0  -6.0  -7.0  -9.0  -9.0
    1.20    18.0  13.0  11.0  10.0   9.0   8.0   6.5   5.0   3.0   1.0   0.0   0.0  -3.0  -6.0  -7.0  -9.0  -9.0
    1.24    18.0  13.0  11.0  10.0   9.0   8.0   6.5   5.0   3.0   1.0   0.0   0.0  -3.0  -6.0  -7.0  -9.0  -9.0
    1.28    18.0  13.0  11.0  10.0   9.0   8.0   6.5   5.0   3.0   1.0   0.0   0.0  -3.0  -6.0  -7.0  -9.0  -9.0
    1.32    18.0  13.0  11.0  10.0   9.0   8.0   6.5   5.0   3.0   1.0   0.0   0.0  -3.0  -6.0  -7.0  -9.0  -9.0
    1.36    18.0  13.0  11.0  10.0   9.0   8.0   6.5   5.0   3.0   1.0   0.0   0.0  -3.0  -6.0  -7.0  -9.0  -9.0
-Carl
slo-svt
Post by slo-svt »
In-Tech wrote: Tue Jul 10, 2018 1:57 am There are other tables to consider besides the high octane timing table you posted.
Code: Select all
  Eq. Ratio                                                    RPM
Code: Select all
  gm/cyl.                                                  Deg. C
I zero ect out above 100f and the pe table completely i also zero out iat table until about 120 which it was below.The only adder that should have been in play was the flex fuel adder and main spark table.
joe 90 wrote: Sat Jul 07, 2018 7:44 pm
So do I just keep retorquing the factory tty fasteners, everytime assuming it loose from the previous time until they finally break? What is the end result with your test? What do I stand to learn from it? I am all for testing but you test is flawed when using tty fasteners...
Update:
The head gasket was not the issue. The piston has a chunk missing (corner of intake valve relief to top ring land) and the sleeve is cracked... I have to look more into it tonight but my initial assumption is it detonated and broke the piston and then hydrauliced and cracked the sleeve. I have to check and see if the rod is bent or damaged when i get the engine out and inspect the rod bearing for detonation marks. I also am feeling like there may have been an issue with ptv the more i look at the pictures which could have just have easily caused both. I will look a little closer tonight after work.
Albert Einstein
gruntguru
Post by gruntguru »
You say you "recently" switched to E85. What was the previous fuel? It's not easy to detonate E85. Is it possible the damage started on the previous fuel?
