Ls3 trunion upgrade.
I received a Brian Tooley Racing trunion upgrade kit that the customer had gotten for his build. Looks good ,however I was expecting to see bushings not needle bearings. Looking for opinions on this for an extreme endurance engine running around 6000-6500.
- midnightbluS10
Re: Ls3 trunion upgrade.
There's 2 different kits. The original upgrade of caged needle bearings, like your customer provided, and the trunnion bushing upgrade. See if you can return those to BTR and pick up a bushing kit from him. Considering it's an endurance application, I'd want nothing less.
JC -
Many inter web posts about bronze glitter in the oil of new ls builds....
It is coming from the bronze rocker bushing kits....
I like the bearings.
Thanks guys. I ordered a set CHE ones so I will have both for the guy to decide on. Anymore input is greatly appreciated.
Anyone here have a terrible experience with the stock bearings? Ive seen high mileage, neglected stuff with needle bearings in the pan. But I've yet to fail one on my own stuff. Not saying they can't or don't. Im just reluctant to introduce issues to something I haven't had issues with. A friend has the Smith Bros bushings installed in his LS7, been in there awhile, also no issues.
I've found it just as cost effective to replace the rockers with new GM units...if there's concern with the needle bearings.
You can replace them every time you do a spring change for instance...for about the same cost as these bushing kits.
new intake/exh rockers from GM run about $200-220 for 16 pcs.
Yeah, you can find them for about 10.00ea. I like the idea of just cycling out the GM parts, that's my plan with the lifters on my LS3 build.A_VAS wrote: ↑Fri Jul 06, 2018 11:00 am I've found it just as cost effective to replace the rockers with new GM units...if there's concern with the needle bearings.
I have abused the hell out of a few sets of high mileage ls3 rockers, and never had 1 fail.
I'm talking 7800rpm shifts with a junk yard 6.0 10second 5dpd GForce stick shift combo.
EDIT: I have never had the bearings fail, but I did make some mistakes and destroy the rocker tip surfaces on 1 aggressively cammed combo
the early ones had some durability problems with the needles popping out and GM fixed that because it was costing them warranty money. I owned a 97, 99, 02, 05 and 08 corvettes and never had a problem.
little food for thought, if you are considering the trunnion 'upgrade'
I removed and disassembled this engine last week (not mine), LS3, ~20K miles on the rockers after trunnions were changed to the Comp kit.
shafts aren't hard enough is my guess, the needles just tear them up
after enough clearance develops, the needles fall out...then the rocker is running off kilter on the valve tip
not good.
I've never seen a GM stock rocker fail like this
needles all thru the engine...valve tips chewed up, etc
not good.
That's very disturbing A_VAS. Was it just the one or do they all show bad signs?
-Carl
-Carl
7 of the exhaust rockers seem fine. 1 was starting to loosen up
all 8 intakes were shot.
maybe the intake side loads the needles / trunnion wierd or something due to the offset
That sounds reasonable, I didn't pay attn. when you stated ls3. I feel a bit better and will keep my fingers crossed for the very few LS1 type rockers I have put those trunnion kits in during a cam change. Those $10.00 new stock rockers don't look too bad after all.
-Carl
-Carl
