Got my pig to pass smog, I can legally do a 6.0 swap for more torque.
24 tooth reluctor wheel
Plan on smallish cam, ported GM heads (which casting do you recommend)
DD type motor, stock manners needed just more umph. Cast crank Ok
Suggestions, sources? Ca CL want a fortune for an old core whos got one ready to go? $$?
6.0 for 02 1500
Re: 6.0 for 02 1500
In the repair biz these folks are reallly good !
Car-Part .com
Looks like $1500. -3000.
Dave B
Car-Part .com
Dave B
LIGHT 'EM UP
Re: 6.0 for 02 1500
243 or 799 castings unless you dont want that much compression. A flat top 6.0 will have 10.5 to 10.8 or so wirh those castings.
An early Z06 cam has good manners and could work good for towing. 204 211 116 i believe.
Re: 6.0 for 02 1500
What engine is existing in the truck?
You will have to be careful if its Calif. emissions as the engine types like the 4.8L and 5.3L LS's have a much lower CO and HC and Nox numbers in the computer test on the emissions dyno and a 6.0 with any kind of aftermarket performance upgrades will be hard to tune lean to pass test.
If you are just going to have to test in a state where they look under the hood and do a simple pass/fail test you could most likely make it fly.
Re: 6.0 for 02 1500
A belt driven intake manifold (TVS 1900) is a great addition to a 5.3 for towing.
73 Omega, 468 BBO, 4.185 ICON Pistons,RR/Wenzler Heads with HS 1.7 rockers and PAC 1220X Springs,J&S 5-main Halo with Billet Caps, .590I .580E 242I 256E HR Cam, 1000hp Carb,2" x 3 1/2" headers,Coan 2900rpm Conv.,TH400,3.73 12 bolt,11.32/118
Re: 6.0 for 02 1500
no tailpipe test here, just visual and plugging into the port.
Local guy wants 1800 for a 130k mi 6.0 Ill pass...its an old used motor.
