AFR Tech Question
AFR Tech Question
Guys:
A hypothetical/tech question for comparing intake systems.
Given the same engine, same atmospheric conditions, same fuel, same inlet size (area), same dyno/race car, etc. (In other words – an ideal scenario for performance comparison of intake systems).
If this engine produces the same air fuel ratio value & trend from beginning rpm to ending rpm – does it matter what the induction system is as far as power is concerned? [Carburetor(s), carb location, EFI, MFI, inlet location, injector location, # of injectors…]
Note: Posting this on a few sites...
Mike Laws Performance
- Stan Weiss
Re: AFR Tech Question
Hey Mike,Mike Laws wrote: ↑Thu Jun 28, 2018 11:35 am Guys:
Is there any difference in fuel droplet size produced by the different systems?
Stan
Did they burn the same amount of fuel to make the same hp?
If it's delivered equally homogenized between type into the combustion chamber, it may not matter the means of introduction.
Mike,
it seems to me, in simple layman's knowledge, there is no way to arrive at a "perfect world answer" [maybe in engineering theory, but in practical application, something always is a fly in the ointment.] You know from talking with me and watching videos of my work that my packages run well and win races. Yet, I never consider anything fully developed, always think something is beyond where I am now.
I have raced your old BLP carbs, other carbs, Ron's injection and find all of them to excel in one way over the other.
I do want to test one of the twin blade deals at some point.
AFR Tech Question
Hey Stan!Stan Weiss wrote: ↑Thu Jun 28, 2018 1:59 pmHey Mike,Mike Laws wrote: ↑Thu Jun 28, 2018 11:35 am Guys:
Stan
There are no constraints or restrictions in mind. Pls feel free to think outside the box...
Mike
Great question! This is not a 'focused' real-world test (yet), so I cannot answer your question about consumption or bsfc. It would be a good follow-up...
Homogenization is definitely involved. I'm trying to figure out how involved it is and looking for ideas and practical experience to prove/disprove...
Based on your wording.. most definitely. Charge cooling and pulse strength(density), pressure stacking, etc. Just injector placement along can aid charge cooling and make life easier with more latitude in manifold design. Think dry manifold vs wet.. dry is more forgiving and allows larger csa without as many low piston speed fuel suspension related negatives.Mike Laws wrote: ↑Thu Jun 28, 2018 11:35 am Guys:
Hey Larry. Big fan here!Dragsinger wrote: ↑Thu Jun 28, 2018 4:52 pm Mike,
We agree. Nothing is fully developed, so there is always room for improvement.
You'll like the twin blades. "It's physics..."
I'm thinking out loud so bear w/me. Are you saying that you can affect power by using any combination of the above systems all-the-while keeping the same afr's?groberts101 wrote: ↑Thu Jun 28, 2018 5:45 pmBased on your wording.. most definitely. Charge cooling and pulse strength(density), pressure stacking, etc. Just injector placement along can aid charge cooling and make life easier with more latitude in manifold design. Think dry manifold vs wet.. dry is more forgiving and allows larger csa without as many low piston speed fuel suspension related negatives.Mike Laws wrote: ↑Thu Jun 28, 2018 11:35 am Guys:
Sure either separate or combined induction design philosophies. High OR low injector placement(OEM's are doing it both ways, ie; direct injected) and high AND low injector placement(OEM's again).. plenum mounted(via F1), common plenum or split plenum, cross rams, IR in both short and long designs depending on desired torque/engine speed range emphasis. Shorter runners with bigger taper.. longer runners with smaller taper having same inlet sizing.Mike Laws wrote: ↑Thu Jun 28, 2018 6:06 pmI'm thinking out loud so bear w/me. Are you saying that you can affect power by using any combination of the above systems all-the-while keeping the same afr's?groberts101 wrote: ↑Thu Jun 28, 2018 5:45 pmBased on your wording.. most definitely. Charge cooling and pulse strength(density), pressure stacking, etc. Just injector placement along can aid charge cooling and make life easier with more latitude in manifold design. Think dry manifold vs wet.. dry is more forgiving and allows larger csa without as many low piston speed fuel suspension related negatives.Mike Laws wrote: ↑Thu Jun 28, 2018 11:35 am Guys:
Seems obvious that some/many of those combo's may require specific AFR's for best power output that may not be identical to one another, but in that same token there may be some similarities for some combinations of parts despite not having identical style induction systems. Fuel efficiency be damned one combination may make best power when spitting flames out the collectors while another may have far superior combustion chamber/space design and require far less ignition lead to make similar power numbers. Just far too many variables and seems entirely feasible that even just a plenum change(design and/or volume) alone could add power without throwing a major wrench in the AFR between two otherwise identical engines.
The first question could be "are we referencing AFR as measured by air and fuel turbines or via accurate wide band sensors?" If the former, large unburned droplets might be present, so equal indicated AFRs could result in quite different combusted values, with a marked effect on power. Poor mixture preparation might also result in a slow burn that reduced power regardless of spark adjustments.
Also, depending on the fuel distillation curve, inlet air and engine temperature, etc., a fine-atomizing carb might produce max power at the same 'combusted' AFR as a coarse one, but due to the conflicting effects of evaporative cooling and charge displacement by fuel vapor, the power could be substantially higher or lower.
Exactly. Ingestion value? Or digestion value?MadBill wrote: ↑Thu Jun 28, 2018 10:33 pm The first question could be "are we referencing AFR as measured by air and fuel turbines or via accurate wide band sensors?" If the former, large unburned droplets might be present, so equal indicated AFRs could result in quite different combusted values, with a marked effect on power. Poor mixture preparation might also result in a slow burn that reduced power regardless of spark adjustments.
Not sure why anyone would target a given AFR. Its just a number. If you went from a junk carb to a carb with great emulsion and atomization you could theoretically get the same AF from both with the great carb using less fuel volume but making more power; due to far greater combustable surface area of the mixture.
You wont beat anyone if you do everything the same as everyone.
