Reference on diagnosing engine failures
ptuomov
Post by ptuomov »
Does anyone know a comprehensive reference for diagnosing engine failures? Looking for a book specifically about the topic.
Put Search Keywords Here
hoodeng
Re: Reference on diagnosing engine failures
Post by hoodeng »
'Engine failure analysis', by Greuter and Zima
Cheers.
ptuomov
Post by ptuomov »
hoodeng wrote: Sun Jun 24, 2018 7:59 pm 'Engine failure analysis', by Greuter and Zima
Cheers.
Thank you, ordered.
Geoff2
Post by Geoff2 »
Better glasses & a better hearing aid. Just kidding, couldn't resist....
Kenova
Post by Kenova »
Geoff2 wrote: Mon Jun 25, 2018 5:33 am Better glasses & a better hearing aid. Just kidding, couldn't resist....
That hits pretty close to home for some of us Old Farts. :lol:
Ken
Over the hill but still learning!
Retaining it is the hard part.
ptuomov
Post by ptuomov »
Kenova wrote: Mon Jun 25, 2018 9:40 am
Ken
Yes, it's a problem. I'm 44 now and my night vision is basically gone, and hearing has become highly selective.
statsystems
Post by statsystems »
Cheers.
WTF???? I can only find used books online and the cheap one is ~160 bucks.
Is the book THAT good?
Frankshaft
Post by Frankshaft »
statsystems wrote: Mon Jun 25, 2018 2:16 pm
Cheers.
Not sure why you would even need something like that. If it blows up, what came first, the chicken or the egg? Otherwise, I think it's pretty self explanatory. Piston skirts are scuffed bad? Probably not enough Piston to wall clearance, if the bearings are chewed up, likely a clearance and or oiling issue, bent valves? Only a couple things that could be, Etc Etc
ptuomov
Post by ptuomov »
Frankshaft wrote: Mon Jun 25, 2018 2:48 pmNot sure why you would even need something like that. If it blows up, what came first, the chicken or the egg? Otherwise, I think it's pretty self explanatory. Piston skirts are scuffed bad? Probably not enough Piston to wall clearance, if the bearings are chewed up, likely a clearance and or oiling issue, bent valves? Only a couple things that could be, Etc Etc
What's obvious to you isn't obvious to me. I don't build engines for living, and have to spend a lot of time sitting in front of a computer. Because of this, I figured that reading a book might be a good way to mitigate the impact of my experience and deficiencies. What's the worst thing that could happen just because of reading a book? Maybe overconfidence? Overconfidence is something that seems to be a risk in this area regardless of how you learn, from a book or from some parts.
hoodeng
Post by hoodeng »
Yes ,the book is that good. This is not a book of show and tell amongs't racers, workshops or experience trained experts ,this book is about analysis from and professional metallurgical perspective , it is not a one product focus so don't expect to read about a certain Ford or Chevrolet problem .
Some years back we saw a certain engine have crankpin failures ,there was a manufacture time window involved , that said ,at the time an opinion was formed by a number of guys involved in the repair of these engines ,,,,they were wrong ! the description of the primary fault through to its ultimate failure was documented in this book perfectly ,it was a small machining/ fitting imperfection.
Ultimately it is up to the person inspecting a fault , if he knows enough about what is in front of him, that's great , If he wants to delve deeper into the failure this book will give insight to the metallurgy .If i operated a trunk engine that failed ,i would want a whole lot better than an opinion , i would want the manufacturers expertise involved.These are engines that are designed to give very long service life with 100% reliability and operate at close to their rated power 24/7.
I have a copy of the 'Mahle piston manual' that give the manufacturers assessments of piston failures ,ahhh, not all is as it seems!!!
Cheers.
hoodeng
Post by hoodeng »
vannik
Post by vannik »
Cheers.
It is published by the SAE and if I remember right, $109 new.
“Ignorance more frequently begets confidence than does knowledge.” -Charles Darwin, The Descent of Man
hoodeng
Post by hoodeng »
I bought mine directly from SAE the id is ,'SAE book order number R-320' or ISBN 978-0-7680-0885-2
there is also this from Mahle
https://www.scribd.com/document/3490653 ... Manual-pdf
and this.
https://www.mahle-aftermarket.com/media ... ochure.pdf
The photos i put in above are taken from an old Mahle piston manual that was given to me when the Mahle distributor for Australasia at that time shut down.
Cheers,
Frankshaft
ptuomov wrote: Mon Jun 25, 2018 3:06 pm
Don't take that the wrong way. I am just saying. And your right, reading never hurts anyone. If the book wasn;t $160 I wouldn't be apposed to it. For engine failures though, it is pretty obvious usually. Just an examples, valve train in clattering, adjust valves. Make a pass, or some laps, or drive it a bit. Starts clattering again, same rocker is lose again. Uh Oh. Under further inspection, come to find out a cam lobe is going flat. Pull engine down, bearings are full of trash, skirts and cylinders have some trama, etc. It's pretty obvious, the lifter stopped rotating, starting chewing up the cam and bottom of the lifter. The damage to the rest of the engine was from the trash floating around from the cam and lifters.
The other thing, make them not fail, and you don't need the book. :D
Kevin Johnson
Post by Kevin Johnson »
vannik wrote: Tue Jun 26, 2018 12:58 am
Cheers.
https://www.sae.org/publications/books/content/r-320/
Auf Deutsch: https://www.booklooker.de/B%C3%BCcher/A ... n+Ursachen
Aside: It might not be the case here but I have often found that English versions of German technical manuals are dumbed-down.
