602 crate block
tracyracin
602 crate block
Post by tracyracin » Thu Jun 21, 2018 8:16 pm
I really hope this doesn't turn into a pissing match.
I want to build a back up engine this winter to my open engine. I have a dog turd of a 602 laying in the shop. Has anyone used the block to make a .040 or .060 over engine? **I am not trying to cheat up a crate engine** all I want to use is the block. Obviously I'll sonic test and all that.. but am I wasting time from the get go?
af2
Re: 602 crate block
Post by af2 » Thu Jun 21, 2018 8:20 pm
The block is fine.
GURU is only a name.
tracyracin
Re: 602 crate block
Post by tracyracin » Sat Jun 23, 2018 10:35 am
Okay. I wasn't sure if people have noticed the castings being thinner or not
Frankshaft
Re: 602 crate block
Post by Frankshaft » Sat Jun 23, 2018 12:10 pm
Keep in mind, on over bores, your reducing cylinder thickness by half the amount in any one spot. From .030 to .040, the bores are only .005 thinner. That's nothing. And at .060 its only .015 thinner from .030
Charliesauto
Re: 602 crate block
Post by Charliesauto » Sat Jun 23, 2018 10:38 pm
If it's the same casting the 604's and 603's use, it should have 880 cast on each side.
We have used these up to 4.050" bore at over 500 HP in circle track engines, we do convert to billet main caps. The center three mains are notorious for breaking at 450 HP an above.
tracyracin
Re: 602 crate block
Post by tracyracin » Tue Jun 26, 2018 7:08 am
Where did you get the billet caps at? I am looking to for something in the 625 range on hp.
midnightbluS10
Re: 602 crate block
Post by midnightbluS10 » Tue Jun 26, 2018 7:42 am
Isn't it just a pretty standard 350HO style block? They should be available from lots of places, AFAIK. Everything I see says those blocks are nothing special.
dirtywhiteboy
Re: 602 crate block
Post by dirtywhiteboy » Fri Jun 29, 2018 1:34 am
10243880 works for 604 or 602, 14093638 can be a 602 only....casting number on back of block below dizzy!
