Engine simulation programs ??
Turbo231
Post by Turbo231 »
I am looking to purchase an engine simulation program and am soliciting recommendations. What is your favorite and why? Thanks.
Kevin Johnson
Re: Engine simulation programs ??
Post by Kevin Johnson »
http://vannik.co.za/
Read all the posts about Neels and his software on this forum.
mk e
Post by mk e »
I like dynomation. It does a good job and is pretty easy to use for most things.
Mark
Mechanical Engineer
David Redszus
Post by David Redszus »
Kevin Johnson wrote: Thu Jun 21, 2018 12:00 pm http://vannik.co.za/
X2
Art Smith
Post by Art Smith »
X3
Art
artesmith@earthlink.net
RaptorLou
Post by RaptorLou »
I have dynomation. Just make sure you feed it with lots of known data for best results. I use pipemax to bounce against. I use Jones cam selector to help as another source. Actually I believe pipemax and Jones have teamed up now....
Lou
If it isn't broke push it harder :D
dennis h
Post by dennis h »
X4
dennis h
V Remian
Post by V Remian »
Kevin Johnson wrote: ↑Thu Jun 21, 2018 9:00 am
X5
hoffman900
Post by hoffman900 »
V Remian wrote: Thu Jun 21, 2018 7:52 pm
X5
X6
-Bob
Post by MadBill »
A theme seems to be developing... :-k :)
gruntguru
Post by gruntguru »
Do these programs allow the user to choose metric or imperial units?
mk e
Post by mk e »
gruntguru wrote: Fri Jun 22, 2018 3:39 am Do these programs allow the user to choose metric or imperial units?
DM let's you switch back and forth so you can enter bore in inches, valves in mm or whatever.
Mark
Mechanical Engineer
mk e
Post by mk e »
RaptorLou wrote: Thu Jun 21, 2018 6:13 pm I have dynomation. Just make sure you feed it with lots of known data for best results. I use pipemax to bounce against. I use Jones cam selector to help as another source. Actually I believe pipemax and Jones have teamed up now....
Lou
I have PM and DM. I used to use PM to get an idea of header size to start with, but DM6 gives me that info so I never bothered to re-register my PM licence on my newer computers.
Mark
Mechanical Engineer
Turbo231
Post by Turbo231 »
Has anyone run the same engine setup through multiple simulation programs and compared results? I know in other fields of science, which use some type of simulation, they might take an average from several programs to get closer to the real answer.
mk e
Post by mk e »
MadBill wrote: Thu Jun 21, 2018 9:52 pm A theme seems to be developing... :-k :)
Its funny because the couple people I know with both engmod and DM say they do most of their work on DM because it's much quicker to setup and has automated iterations. Then once they have everything DM can deliver they may plug it into engmod if there are additional questions DM doesn'tanswer....but that's second hand so....
Mark
Mechanical Engineer
