Indy AMC Aluminum Block-Cam Core
GOSFAST
Post by GOSFAST » Wed Jun 20, 2018 8:24 am
Need help locating new (or even good used) cam core for an all-aluminum AMC block.
Am contemplating getting into a build with one of these units, have most of the components here already.
Have tried some of the larger cam companies, no help so far, have left message with Indy but they haven't got back to me yet!
Thanks, Gary in N.Y.
P.S. Would mention also core needs to be based on the 55mm platform.
Jan. 2016 - New York Street Ride 7.56 @ 190 @ 3800#
(https://www.google.com/url?sa=t&rct=...12064104,d.cWw)
In-Tech
Re: Indy AMC Aluminum Block-Cam Core
Post by In-Tech » Wed Jun 20, 2018 6:11 pm
Steve Lowe Sr. @ LSM would be a good call.
4670 Hatchery Rd
Waterford Michigan 48329
tel:248-674-4967
fax:248-673-7089
email:lsmeng@sbcglobal.net
http://www.lsmeng.com/
-Carl
Krooser
Post by Krooser » Fri Jun 22, 2018 2:45 pm
Andrewsproducts.com
Last place in the B-main is better than anyplace in the grandstands...
ProPower engines
Post by ProPower engines » Sun Jun 24, 2018 4:05 am
4670 Hatchery Rd
tel:248-674-4967
fax:248-673-7089
X2
They are who we get our custom BBmopar cams from. They seem the most willing of all the cam suppliers to do uncommon stuff.
AMC is in the odd ball league for a fancy cam type but it is right up their alley =D>
GOSFAST
Post by GOSFAST » Sat Jun 30, 2018 5:43 pm
Would like to thank everyone here for the help on this one, so far it look's like we'll be building an all aluminum AMC, it's a "first" for me, at least in aluminum!!
P.S. We MAY "shrink" the 55mm cam bores back to "standard" (not decided yet), will ease the cam core situation some?
piston guy
Post by piston guy » Mon Jul 02, 2018 12:40 pm
Herman Lewis in Beckly WV was a good source on AMC stuff. I know he had at least one of those blocks. I'm sure you probably already know that. A.H. Adkins is another AMC guru.also in WV as I recall.
AMXstocker1
Post by AMXstocker1 » Sun Jul 08, 2018 12:41 am
call comp and talk to Tim Cole. have a friend who recently purchased a tool steal cam core from them.
Jeff Lee
Post by Jeff Lee » Tue Jul 10, 2018 12:21 am
Tim Cole retired from Comp Cams in December 2017.
I use 55mm cam cores in my AMC 390. It is a standard cast-iron production block. I get my cams through:
Spiro Jennings
Red Line Racing Cams
1304 Short Ridge Avenue
Unit C
San Jose, CA 95116
Ph: 408-292-0646
He designs and machines his cams at his shop. I know of NHRA Stock, Super Stock, Comp and Pro-Stock (car and MC) that run his cams successfully but often time the racer keeps it under wraps. Although there are no guarantee’s in racing, I can tell you it’s likely you will get one of Spiro’s cams and two things will happen; 1) you won’t be wanting for more, and 2) your valve train will be very happy.
NHRA SS/H
1970 AMX
390 4-speed
Advanced Clutches
