Compound boost not as expected
craigory
Post by craigory » Wed Jun 20, 2018 12:02 am
Hi all.
I have a 2.3 sohc lima turbo.
For nothing but fun I twincharged it with an m62 from a Mercedes clk (mag pulley eliminated) then blew into that with a H1c Holset turbo with a large exhaust turbine housing.
My aim was to compound the boost beyond what the back pressure is at the turbo, change up what the normal characteristics are for a turbo only motor.
Using a modified external wastegate as a supercharger bypass. (Credit to warpspeed!)
Using a 44mm external wastegate for the holset turbo.
BOV in between the turbo and charger.
W2A IC between the turbo and charger
FMIC after the charger.
Megasquirt 3 pro engine management.
With the charger at 2:1 crank ratio I was getting 4 psi boost. No spring in turbo wastegate so no boost to charger.. Charger only mode...
Spring installed in wastegate, boost builds from turbo and the compounding charger supplies 8.5 psi MAP at approx 4k rpm with around 4-5 psi from turbo..
Boost from turbo keeps climbing but the compounded boost remains at 8.5 psi....
I was expecting the charger to compound the boost the whole way up the rev range.. Take whatever is presented to its inlet and compress it further..
Why does it plateau?
blown265
Re: Compound boost not as expected
Post by blown265 » Wed Jun 20, 2018 1:13 am
Hi mate
Some time ago, I attempted using an external gate as a bypass on an Eaton SC in blow through configuration like yours, but wasn't able to get it to function as needed. The problem may have been in the way I'd installed it, but trialling different setups didnt improve the outcome.
I've since changed to a series of staggered opening point factory bypasses* and this has worked perfectly. The pressure can be vented back to the aircleaner, or straight to atmosphere.
(*the Eaton OEM butterfly valve style bypass seems to discharge better than a valve/spring arrangement like a gate, when exposed to the continuous air supply from a positive displacement SC)
I wonder if your external gate is bleeding compounded boost? (cycling open/closed or something equally unusual)
Regards
Paul
englertracing
Post by englertracing » Wed Jun 20, 2018 1:24 am
What you have done is really cool and im really into the limas....
I also love superchargers, turbos not so much,
But both.... Now, thats something.
But im having trouble understanding why not just use a large turbo before the SC and a bypass around the sc for when the turbo is spooled,
Like a lancia delta rally car.
gruntguru
Post by gruntguru » Wed Jun 20, 2018 1:59 am
Disable (block) the bypass and see what happens.
craigory
Post by craigory » Wed Jun 20, 2018 8:06 am
Hi mate
Regards
Paul
Hi.
I Have a supercharger bypass butterfly valve from a mini Cooper i used on another install. It wouldn't glide onto boost very well when being used as a BOV and vented to atmo, it would flip onto boost very uncontrollably so part throttle driving/cruising was a real pain.
I had to install a throttle body before the charger to get it all to behave..
2 throttle cables, pita of course..
What you mean by staggering opening points.?
craigory
Post by craigory » Wed Jun 20, 2018 8:14 am
Thats a parallel type sysyem. Either one or the other, getting the transition from one to the other isn't easy too.. But its still only turbo only up top.
I'm trying to compound boost beyond exhaust turbine back pressure. Have more pressure at the inlet valve than back pressure at the exhaust valve.. most turbo engines will create way more back pressure than boost..
Run a custom cam thats not turbo profile.
No residual gasses hanging around, less prone to detonation... More ignition timing. Blow straight through with no restriction.
That's was the plan anyways!!
craigory
Post by craigory » Wed Jun 20, 2018 8:16 am
Yes... I have an idea to try now you mention that.. Thanks!
Big Al
Post by Big Al » Wed Jun 20, 2018 9:22 am
I have a gut feeling about the bypass is to small.
A supercharger can only make a certain volume flow at a fixed speed and if the turbo doesn't get enough flow into the inducer you the pressure before drops and PR goes up and you have built a "restrictor turbo" and that caps the mass flow.
craigory
Post by craigory » Wed Jun 20, 2018 10:22 am
Not sure I follow.
Turbo inducer isnt restricted.
Bypass valve bleeds all boost at high rev closed throttle.
Big Al
Post by Big Al » Wed Jun 20, 2018 10:31 am
And now I don't follow too :D
Could you make a simple drawing of your setup?
craigory
Post by craigory » Wed Jun 20, 2018 10:47 am
Air filter- turbo- W2A intercooler- supercharger- FMIC- throttle body.
Bypass valve just before throttle body dumping back to after air filter.
My bypass is an external wastegate with a weak spring setup like a BOV. But I suspect the compound boost is pushing the wastegate off its seat..
Truckedup
Post by Truckedup » Wed Jun 20, 2018 11:05 am
Not that aircraft engines always relate to vehicles.... Dual stage supercharging in aircraft was in series...All US 4 engine bombers and the P38 fighter used a turbo charger to maintain sea level pressure to the carburetor, actually an analog throttle body injector.up to around 25,000 feet... Then a mechanical supercharger boosted the sea level pressure for the desired level of power...
Big Al
Post by Big Al » Wed Jun 20, 2018 11:19 am
Now I get it, thought you had the supercharger before the turbo... So ignore my post.
I think you are right, the bypass have too weak spring. Like others already said, try block it and see if it helps. :)
englertracing
Post by englertracing » Wed Jun 20, 2018 11:35 am
Same for some reason i think the first post gives this impression.
englertracing
Post by englertracing » Wed Jun 20, 2018 11:39 am
Those superchaegers are of the centrifugal compressor type, the roots wont provide much of any compression, its a fixed volume pump. A screw may compound better.
