Sbc timing chain install
tracyracin
Post by tracyracin »
Does it matter if I'm on the compression stroke for tdc? Installing with odd side head on and I have #6 cyl at tdc. I need to know if it matters which stroke it's on when lining up the dots. Thanks
GARY C
Re: Sbc timing chain install
Post by GARY C »
I believe dot to dot is #6 compression stroke and when rotated to #1 both dots are in the up position.
tracyracin
Since I can't see number 1 cyl I'm trying to use number 6 as a guide.
GARY C
Post by GARY C »
tracyracin wrote: Tue Jun 19, 2018 8:20 pm Since I can't see number 1 cyl I'm trying to use number 6 as a guide.
1 and 6 have the same TDC
tracyracin
GARY C wrote: Tue Jun 19, 2018 8:32 pm
Okay good. But do i need to make sure I'm on the right stroke when lining up the dots?
GARY C
Post by GARY C »
tracyracin wrote: Tue Jun 19, 2018 8:45 pm
It's been a while but if I recall the dot on the crank is up on #6 compression and down on #1, I think I said that wrong earlier. Set it up and see.
lefty o
Post by lefty o »
if your replacing the chain on an already running engine, remove the cover, roll it over so the gears are dot to dot and replace.
Post by MadBill »
tracyracin wrote: Tue Jun 19, 2018 8:45 pm Okay good. But do i need to make sure I'm on the right stroke when lining up the dots?
No, the cam determines which is the compression stroke, you just have to index it correctly to the common TDC position of cylinders 1 & 6. To be clear, if you had the driver's side head off you'd see the #1 piston also at TDC.
In-Tech
Vendor
Post by In-Tech »
Hi Gary,
It was said correctly in an earlier post, when the dot on the crank is up, #1 and #6 are both at TDC, when the dot on the crank points at the dot on the cam gear, it is #6 compression. When the crank dot is up and the cam dot is up, it is on compression #1. :)
edit. Sorry Bill, just noticed you already said that.
-Carl
GARY C
Post by GARY C »
In-Tech wrote: Tue Jun 19, 2018 9:07 pm Hi Gary,
Thanks for clarifying, I remember we never thought about it until we thought about it and then it became confusing when it didn't need to be. :)
In-Tech
Vendor
Post by In-Tech »
GARY C wrote: Tue Jun 19, 2018 9:15 pm
Hahaha, we only had to stab ONE distributor 180 out :lol:
-Carl
tracyracin
GLHS60 wrote: Tue Jun 19, 2018 9:20 pm Exactly, dot to dot, the rotor points to # 6, and # 1 valves are on overlap.
Both dots up, the rotor points at # 1, and # 6 valves are on overlap.
If you can get comfortable recognizing overlap, it comes easy.
Thanks
Okay so as long as I do dot to dot I'm good to go? I guess I'm just second guessing myself. Have alot riding on this engine and I'm very novice. Lol
GARY C
Post by GARY C »
In-Tech wrote: Tue Jun 19, 2018 9:24 pm
Yeah, in the early day's of cam swap you just lined up the dots before taking out the old cam and never thought about TDC or Compression stroke, then one night a friend called me with this question and I had to go out and mock up a short block so i could answer the question. This is one of those times when more knowledge causes unnecessary confusion. :)
In-Tech
Vendor
Post by In-Tech »
tracyracin wrote: Tue Jun 19, 2018 9:31 pm Okay so as long as I do dot to dot I'm good to go? I guess I'm just second guessing myself. Have alot riding on this engine and I'm very novice. Lol
I assume you are trying to degree the cam based on #6? If so, it's close enough. Of course we don't know how well the crank is indexed and blah blah blah. Carry on. :D
Oops, internet vomit worm can. 8)
-Carl
tracyracin
In-Tech wrote: Tue Jun 19, 2018 9:38 pm
I had a hex-adjust bushing come apart and I took the timing chain off with out even thinking about the dots. The passenger head is off due to a damaged valve. So I'm using 6 to find tdc. But now that I think about it it's really not needed? I wrote down the bushing setting for 4 degree advance from when I degreeed the cam in weeks ago.
