A dream part you wish for!
Mike Laws
Re: A dream part you wish for!
Post by Mike Laws » Thu Jun 14, 2018 9:38 am
PbFlinger wrote:
Wed Jun 13, 2018 3:15 pm
9/16 socket w/gps locator
Great answer!
Mike Laws
Get'm Garage
Home of the Twin Blade Series carburetors, Titan Metering Blocks, Piston Cooling System and more...
CharlieB53
Post by CharlieB53 » Tue Jun 26, 2018 12:42 pm
I've always been in love with the old Detroit 2 strokes. I want a gas version with that blower over-running clutch so once the turbo spools up the blower free wheels. Of course intercool the turbo but also have an AC cooled intercooler brick under the blower.
Another idea I've had for a very long time an NA intake with Merc Marine intake reed valves is close to the head as possible. This should tame the reversion at idle and allow much more cam on the street.
Post by MadBill » Tue Jun 26, 2018 1:02 pm
Sponge rubber hammer for the 'ambi-clumsy' among us.
Geoff2
Post by Geoff2 » Wed Jun 27, 2018 5:07 am
Bill,
Could you order two hammers....
BigBlocksOnTop2
Post by BigBlocksOnTop2 » Wed Jun 27, 2018 8:50 am
My dream part would be an Autolite inline 4bbl carb and adapt it to my 69 Stang....395 W.
Belgian1979
Post by Belgian1979 » Wed Jun 27, 2018 5:41 pm
Something that makes a license plate unreadible when a picture is taken...for real. :D
F-BIRD'88
Post by F-BIRD'88 » Wed Jun 27, 2018 9:17 pm
A Edelbrock SBC Tunnel Ram (carbs) that is for the Vortec / E-TEC / Fastburn cylinder heads.
Ditto a roots (6-71) supercharger intake manifold for same.
F-BIRD'88
Post by F-BIRD'88 » Wed Jun 27, 2018 9:40 pm
A street strip carburetor with 6 venturi... "6 barrel"). Like a AFB carb or a Qjet but with central 2 (small) primaries and 4 big secondaries 2 front ,, 2 rear. With air door/velocity valve secondary flow control.
Single carb body. Same width and throttle linkage as existing AFB or Qjet carbs.
Can be used on new dedicated intake manifolds or on existing 4bbl intake manifolds with a simple carb adapter
1200 to 1500 cfm total @1.5"
Could have separated dedicated primary and secondary fuel bowls/floats/fuel inlets
to allow "dual fuel" use. Say gasoline primary and methanol secondaries.
external Adjustable floats
MasterUMC
Post by MasterUMC » Wed Jun 27, 2018 9:55 pm
A SBF belt drive that doesn't cost million dollars and not made in china.
AMXstocker1
Post by AMXstocker1 » Thu Jun 28, 2018 6:12 pm
Affordable aftermarket iron amc block
rq375
Post by rq375 » Thu Jun 28, 2018 7:04 pm
Early to mid 90s E-150 5.0-5.8, the brackets bolt to the heads so they work on either deck height with a belt change. They also have Saginaw power steering pumps.
jeff swisher
Post by jeff swisher » Thu Jun 28, 2018 7:54 pm
I second what F-Bird said on the Vortec Tunnel-ram.
I care less if Edelbrock makes it But I want it tall not those short dual plane ones.
If I had some busted vortecs I would mock up a busted block and make a steel one from pipe.
That has been done before.
I built a 4V intake from steel I had laying around for a 260Z and it worked better than any 4V or FI or dual carb setup i ever had on a Z engine.
gruntguru
Post by gruntguru » Thu Jun 28, 2018 8:06 pm
Tuner wrote:
Sat Jun 09, 2018 2:41 pm
It would be nice to have a seal arrangement that would allow using draw-through carburetion on existing centrifugal superchargers
It is a straightforward mod on most compressors. Two piston ring seals with atmospheric pressure piped into the space between. This paper describes the modification on a small turbocharger.
https://minerva-access.unimelb.edu.au/b ... sAllowed=y
gruntguru
Post by gruntguru » Thu Jun 28, 2018 8:14 pm
paulzig wrote:
Sat Jun 09, 2018 5:01 pm
Electronically controlled valvetrain, you just program in the valve path and you can have whatever cam you want that wont hit the piston.
It will happen. For example Koenigsegg is getting close. https://www.youtube.com/watch?v=S3cFfM3r510
1972ho
Post by 1972ho » Fri Jun 29, 2018 12:04 am
An exhaust system that will make my 2012 Buick Regal GS turbo sound like a formula 1 race car.
