WHICH BRONZE & WHAT PRESS FIT FOR ROD BUSHING
barnett468
Post by barnett468 » Thu Jun 07, 2018 10:12 pm
I'm working an an air cooled single cylinder 250 cc triumph and need to make a bronze bushing for the rod for the floating piston pin. I'm guessing it will probably see around 350 degrees. The id of the rod is around .700 and the thickness of the bushing is .047.
Which bronze would be best to use?
How much interference fit for the bushing/rod?
Thanks for any help.
Charliesauto
Re: WHICH BRONZE & WHAT PRESS FIT FOR ROD BUSHING
Post by Charliesauto » Thu Jun 07, 2018 10:23 pm
Ampco 45 bronze with .0025" press and a little green Loctite works well for us
PackardV8
Post by PackardV8 » Fri Jun 08, 2018 9:49 am
Bushings are difficult to make one off and the catalogs have many options. Much easier to find the OD needed, press in, trim to length and hone to ID.
clshore
Post by clshore » Sun Jun 10, 2018 3:15 pm
Crower and others will make a bushing exactly to your spec …
Just sayin'
