Brain fade - half shelling a .010 bearing for more clearance
MotionMachine
Re: Brain fade - half shelling a .010 bearing for more clearance
Post by MotionMachine »
There are some automotive applications where oversize o.d. bearings are available. I've line bored a couple of BBC's for .010" over mains. The strangest o.s. I've seen is a .015" over for the Kent Ford 1.6 that's used in many things, Formula Ford being one of them. King now makes a .002" and a .005" for Subaru's.
Krooser
Post by Krooser »
Who's on first.
groberts101
Post by groberts101 »
Krooser wrote: Thu Jun 07, 2018 10:05 pm Who's on first.
Abbot!.. err, wait.. or was it Costello? :lol:
Krooser
Post by Krooser »
Actually posts like this get you thinking which is good...
engineguyBill
Post by engineguyBill »
Think of it this way - when a crankshaft journal is ground undersize, a corresponding "undersize" bearing is needed. Therefore a journal that is ground .010" undersize will need -10 (-.010') bearing set which has thicker shells than a STD bearing set does. SO -.009" bearing has thinner shells than a -.010" and -.011 bearing has thicker shells that the -.010". Therefore, a -.009 bearing will result in additional clearance over the -.010" bearing and the -.011" bearing will have less clearance than the -.010" bearing.
When mix/matching bearing shell sizes, the bearing manufacturers recommend that the thicker shell be placed in the cap side of the main bearing and in the rod body of connecting rods. However, I have done it both ways and have not seen any difference/problems.
Bill
SAE Member (30 years)
In-Tech
Vendor
Post by In-Tech »
engineguyBill wrote: Fri Jun 08, 2018 1:25 pm Think of it this way - when a crankshaft journal is ground undersize, a corresponding "undersize" bearing is needed. Therefore a journal that is ground .010" undersize will need -10 (-.010') bearing set which has thicker shells than a STD bearing set does. SO -.009" bearing has thinner shells than a -.010" and -.011 bearing has thicker shells that the -.010". Therefore, a -.009 bearing will result in additional clearance over the -.010" bearing and the -.011" bearing will have less clearance than the -.010" bearing.
Lol, if I read you right Bill, you contradicted yourself.
Time to get the ball mic out.
-Carl
groberts101
In-Tech wrote: Fri Jun 08, 2018 1:32 pm
haha.. reread it again.. he has it right. And even I understood it.. which means he succeeded in dumbing it down enough to get the point across to most knuckle headed nut jockeys. errr.. wait.. that didn't sound right. :oops:
Like I said in the above when I replied too quickly.. I just went through this with my too loosely clearanced SBF mains. I bought the crank off ebay after it was freshened so ended up doing things ass backwards from a building/clearancing standpoint. Bought coated -.011" mains and all was good again.
In-Tech
Vendor
Post by In-Tech »
:lol: Hahahaha, I did have to reread it.
Std journal bearing is 2.100" O.D crank (forget built in clearance for this convo)
-.009 journal bearing is for 2.091" O.D. crank, thicker by .009" per pair of shells vs Std. More clearance
-.010 journal bearing is for 2.090" O.D. crank, thicker by .010" per pair of shells vs Std
-.011 journal bearing is for 2.089" O.D. crank, thicker by .011" per pair of shells vs Std. Less clearance
Krooser was right, this was a good memory lesson.
Sorry Bill, I know you know your stuff. :oops:
-Carl
