Flow bench results
statsystems
Re: Flow bench results
Post by statsystems »
John Wallace wrote: Sun Jun 10, 2018 1:46 pm So a head that flowzz 415 cfm is a lot better than a head that flowz 415 cfm?
(and a lot better than one that flows 415 cfm)
Should make a sticky out of this post.
Sums it up perfectly.
Rick360
Post by Rick360 »
statsystems wrote: Sun Jun 10, 2018 2:24 pm
But a head that flowZZ 415 cfm makes even MORE power than one that only flowzz 415 cfm. =D>
So to sum it up ...
flowZZ > flowzz > flowZ > flowz > flows
Rick
swampbuggy
Post by swampbuggy »
Flows=461 196?
FLOWZZ= DRCE Pro-stock. 2018. LOL. Mark H.
GARY C
Post by GARY C »
swampbuggy wrote: Sun Jun 10, 2018 7:08 am Gary, Matt who is MBE cylinder heads said that they got away from taper in the port and there's more power there with less taper this is on high horsepower stuff. Mark H.
On a better designed induction system you have more control of size shape and cs consistency, my comment was toward as cast 23 degree components. On a single depending on rpm and application you have between 3 and 3.5 sq in at the plenum tapering down to 2 sq in at the flange where a RPM Airgap is near 2 sq in from plenum to flange, on a street vs race tunnel ram you would see a size, length or taper difference.
midnightbluS10
Post by midnightbluS10 »
RevTheory wrote: Sun Jun 10, 2018 9:13 am It's just a long-running funny that Randy came up with a year or two ago. It stuck :lol:
Thank you! I thought I was losing my mind. Or you guys were lol.
JC -
