Flow bench results
n2xlr8n
Re: Flow bench results
Post by n2xlr8n » Wed Jun 06, 2018 3:58 pm
Stan Weiss wrote:
Wed Jun 06, 2018 2:35 pm
If I have adjustable headers and change the primary pipe length and or collector length and see an increase or decrease in et. What caused the change in et?
Stan
Pressure differentials due to wave propagation, algebraic summing, etc.
Frankshaft
Post by Frankshaft » Wed Jun 06, 2018 4:36 pm
Stan
It made more power? :-k
statsystems
Post by statsystems » Wed Jun 06, 2018 4:50 pm
Stan
Or it made less power.
randy331
Post by randy331 » Wed Jun 06, 2018 4:57 pm
Warp Speed wrote:
Wed Jun 06, 2018 1:39 pm
How do I get the right camshaft events?!?
128 of course! 8)
LOL :lol:
Frankshaft
Post by Frankshaft » Wed Jun 06, 2018 5:06 pm
Stan
Right, missed the increase part.
randy331
Post by randy331 » Wed Jun 06, 2018 5:10 pm
Scotthatch wrote:
Wed Jun 06, 2018 10:33 am
... if I need more HP I can up the cfm or move the closing point of the intake valve out more ... now this just deals with peak HP
Wish it was as easy as you make it sound.
Scotthatch
Post by Scotthatch » Wed Jun 06, 2018 5:17 pm
Stan Weiss
Post by Stan Weiss » Wed Jun 06, 2018 5:26 pm
Glad to see Captain Obvious is posting here. :lol:
Stan
swampbuggy
Post by swampbuggy » Wed Jun 06, 2018 6:19 pm
Warp speed did you miss my question about the exhaust and scavenge
Scotthatch
Post by Scotthatch » Wed Jun 06, 2018 6:57 pm
Everyone that has pulled heads and ported them to gain power is doing so to up the cfm flow not to change some wave characteristic .... when you add high ratio rockers and gain power why is it helping? More flow from peak lift? Changing cam specs? Or did it change the waveform?
You guys are so hung up on the cool idea of how to refine a engine you have forgotten the bread and butter of how it works most of the time .....
statsystems
Post by statsystems » Wed Jun 06, 2018 7:24 pm
I have ported heads that flowed LESS and made a good bit more power. A Stage IV Chrysler is one example of an head like that.
randy331
Post by randy331 » Wed Jun 06, 2018 8:02 pm
Take a look at cgarb s 421 vs mine, our IVC are the same and his heads flow more than mine, why does mine make more power ?
If your theory about more cfm and later IVC always making more power is right, his should be making more.
Scotthatch
Post by Scotthatch » Wed Jun 06, 2018 8:21 pm
Is the flow quality the same ? Does the intake support the flow ? Does the carb support the flow? Is the timing the same ? Is it having a burn problem with the fuel ? Was it tested differently?
What it shows is the potential of the engine power you can be lower if things are not correct ....
I posted lots of dyno tests where the HP was dead on
Frankshaft
Post by Frankshaft » Wed Jun 06, 2018 8:23 pm
Define flow quality please.
Scotthatch
Post by Scotthatch » Wed Jun 06, 2018 8:30 pm
When you flow a head just because you hit a number does not mean the air is moving smooth and clean if it is rough on the bench it will stall on the motor ..
