Thanks.. I do need help! Probably much more than Gary does too.Warp Speed wrote: ↑Wed May 30, 2018 1:37 pmJust trying to help you, and the rest of the board for that matter.
All you want to do is argue instead of learn. You must know everything already?!?
We have a saying around here....."all we do know, is that we don't know".
I'm guessing if myself and my colleagues don't know it all, with the experience and resources we have, you have a ways to go yet!
Don't take it as a jab, as I said, I'm trying to help you!
Here's a question I posed in another thread. An extreme example compared to this thread port differences but maybe still shows a small cross section of what happens to a power curve when port size changes between various castings?
Seems that despite most thinking/saying heads and cam's aren't some kind of magic voodoo.. there sure is a lot of debate about them. Maybe some people are inherently more experienced and voodoo literate than others? Then consider the amount of time and resources that go into changing them out and refining the combo on the dyno and it sure seems to be much more difficult to nail an optimum result than some are admitting or letting on about. So ,all that math and estimation of final results don't mean squat until mother nature has final her say in the matter.
Can some of the smarter guys, who hopefully just hate koolaid and not me personally, help me build a paper motor to help better understand how flowZ in relation to CSA(and mCSA) can affect the optimum cam choice?
Let's say I call up a custom cam grinder and tell him I have a 302" SBF street/strip type deal and give all pertinent components(lighter weight 8mm hollow valves, conical springs, Ti retainers, etc), induction, exhaust, chassis weight, tire/gearing, and personal taste or bias of what I can and prefer to live with on the street side of the equation. And based on that info we both agree that a peak horsepower mark should likely fall into the 6,800 rpm range. And that's just peak.. maybe it needs to go/hang on upwards of 7,200 on the shift to ET better.
But wait.. there's more! lol Then I also tell him I have 2 sets of fairely well developed/modified cylinder heads to choose from and haven't yet fully decided which ones will be used.. so grind me 2 cams to suit each specific combo of parts. One set being a smaller CSA/higher velocity port design with peak airflow possibly better matched to the displacement and rpm capability of this shortblock.. the other being a much larger port CSA/slower velocity and far exceeding this OEM shortblocks capability before cracking or splitting in half.
1st set is an RHS 165cc casting that has been rolled over another degree(19°) with welded and moderately raised intake and exhaust ports, with the exhaust port also being plated/extended/angled upwards and shrunk down to accept/match a 1.5" od(1.370") primary pipe coming off the flange, with intention of stepping towards 1.625" od and hitting a merge style collector. Valve sizes are 1.96"/1.54" with 90+% throats.
2nd set is also fairly well developed, a high-port converted Kaase P38 head with MUCH bigger CSA and having mod's very similar to the above RHS's, with the exception of the exhaust ports being matched to a 1.625" pipe off the flange and stepping to 1.75" before heading towards a slightly smaller merged collector choke sizing. valve sizes are 2.16"/1.55" with 87/89% throats.
So finally onto the $10,000 question. Does each custom cam grind he comes up with end up with similar spec's for either head used on this combo?
Because if it does?.. most would naturally think that without even seeing those final cam spec's that the Kaase P38 headed combo will surely give up torque down low and make power WAAAYYYY past the expected peak rpm. And maybe even moreso if that cam matched to work with the RHS headed combo had a relatively fast ramp rates and higher ratio rockers?
