Fresh combo... could have some stuff floating around. Thanks!Tuner wrote: ↑Sat May 19, 2018 12:08 pm First, detonation makes tiny black specks. if you see silver color beads the source is more likely preignition, which can occur without detonation. Preignition results in extreme heat which initially distills metallic vapor of lower temperature melting alloy from the piston before actually catastrophically melting big gobs of aluminum. Detonation can occur and make the black specks without vaporizing or melting any metal from the piston.
On the other hand, if an engine ingests an astonishingly small amount of dust you may see what looks to be detonation. The color and appearance of this type of tiny specks depends on the mineral content of the local dirt or source of the dust. The trace minerals (metals) in the silica melt and fuse into tiny beads which can imitate detonation specs. Some fabric gauze air filters (K&N type) are perfect sifters to admit just the right size bits of dust to make the imitation detonation specks.
Many new cylinder heads have significantly improved "fast burn" combustion characteristics and require much less ignition advance than earlier stuff. You need to retard timing until performance begins to drop off to find the least advance that gives the best performance. Don't be surprised if it is less than 30 degrees for some new chamber and port designs.
DETONATION
Re: DETONATION
Re: DETONATION
I have never been able to get pics on here... I pulled 2 degrees out and it fell off almost 3 mph!Scotthatch wrote: ↑Sat May 19, 2018 1:10 pm I have a couple of thoughts
Can you post a photo of a plug so we can see?
Have tried pulling 4 degrees out and seeing how it effects your ET?
Re: DETONATION
Yes, crank trigger. Thanks.Scotthatch wrote: ↑Sat May 19, 2018 1:42 pmIt also says timing is about right .... I am assuming the timing is fixed ?n2xlr8n wrote: ↑Sat May 19, 2018 1:25 pmHe stated " I ran 1st pass 35 degrees timing 100 octane aviation fuel( 110 jet front and rear ) it ran 129.18 mph trap speed in 1/4 mile drags. I bumped timing back to 33 degrees 100 octane( 110 jet ) after seeing 1 speck of shiny aluminum(?) on only # 1 plug (with 10 power magnification) mph dropped to 126.55"Scotthatch wrote: ↑Sat May 19, 2018 1:10 pm I have a couple of thoughts
That sort of (not always) shoots my fuel volume question in the foot.
Re: DETONATION
When you're typing a reply, there is box with four bars to the right of the word "Options" below the reply box.
Click on it and the word "Attachments" appears.
Click on that and a box labelled "Add files" appears.
Click on it and it will take you to your computer's picture file or something similar.
Click on the image/images you want and then click the 'open' box.
The pic's title will appear in a box below the reply box.
Click on the "Place inline" tab and it should appear in your reply box.
(I've attached a random pic to verify these steps.)
Piece of cake, eh?
Re: DETONATION
Hi Bill. Is that the line 2 line coating?MadBill wrote: ↑Sat May 19, 2018 5:38 pmWhen you're typing a reply, there is box with four bars to the right of the word "Options" below the reply box.
Piece of cake, eh?
And what's on top? Never seen a black TBC before.
And while I'm at it.. is that the actual tape job they did to coat the crowns?
Re: DETONATION
Ya, people seem to want to run the hottest plug they can, when really they should be running the coldest plug they can, without fouling or misfire that is.
Re: DETONATION
Yes ^^ start cold and work 'toward' the hotter side - not melt stuff then back it off!Warp Speed wrote: ↑Sat May 19, 2018 7:47 pmYa, people seem to want to run the hottest plug they can, when really they should be running the coldest plug they can, without fouling or misfire that is.
And only change 1 thing at a time (unless you are sure you will kill the engine!) to get an idea of what each change does and an easy reversal if the change was no good because you know what did what.
Re: DETONATION
it's a ~15 year old Ford Cup piece that came from a shop that builds engines mostly from used Cup parts; I don't think they had L2L back then. Up close it doesn't look porous like the L2L I had applied to build up the pistons for my BBC.groberts101 wrote: ↑Sat May 19, 2018 7:29 pm
The ragged band at the top is just a reflection from the bare aluminum. I had thought it was just worn that way, but upon re-inspection, I think it was taped off.
The ring area is coated with something that resembles anodizing but the crown is untreated. It shows quite a few small damage 'peck marks', but some appear to be from a Rockwell hardness tester indenter, which is used to determine the maximum temperature the metal has reached.
Re: DETONATION
By Jove I think Ive got it Thanks!MadBill wrote: ↑Sat May 19, 2018 5:38 pmWhen you're typing a reply, there is box with four bars to the right of the word "Options" below the reply box.
Piece of cake, eh?
Re: DETONATION
Plug is a little hard to read at this distance ... can we get a close up?redliner wrote: ↑Sun May 20, 2018 1:59 pmBy Jove I think Ive got it Thanks!YABABBBBBY.jpgMadBill wrote: ↑Sat May 19, 2018 5:38 pmWhen you're typing a reply, there is box with four bars to the right of the word "Options" below the reply box.
Piece of cake, eh?
Re: DETONATION
BWWWAAAHAAHAA!!! Thanks but I have it under control...Scotthatch wrote: ↑Sun May 20, 2018 2:46 pmPlug is a little hard to read at this distance ... can we get a close up?redliner wrote: ↑Sun May 20, 2018 1:59 pmBy Jove I think Ive got it Thanks!YABABBBBBY.jpgMadBill wrote: ↑Sat May 19, 2018 5:38 pm
Piece of cake, eh?
- af2
Re: DETONATION
Love your car! Nostalgia racing is all we do!redliner wrote: ↑Sun May 20, 2018 3:31 pmBWWWAAAHAAHAA!!! Thanks but I have it under control...Scotthatch wrote: ↑Sun May 20, 2018 2:46 pmPlug is a little hard to read at this distance ... can we get a close up?
GURU is only a name.
Re: DETONATION
Thanks man! This is my street car! 10.38@ 129+ on second shakedown of new 414/ TKO 600 combo. Yer Willys looks BADASS! How fast? What combo?af2 wrote: ↑Sun May 20, 2018 3:46 pmLove your car! Nostalgia racing is all we do!redliner wrote: ↑Sun May 20, 2018 3:31 pmBWWWAAAHAAHAA!!! Thanks but I have it under control...Scotthatch wrote: ↑Sun May 20, 2018 2:46 pm
