LS1 5.7 camshaft advance
Scotthatch
Post by Scotthatch » Wed May 16, 2018 6:42 pm
I have a LS1 5.7 engine single turbo that I think I need to advance the cam 4 degrees on to help it spool ... if I do this do I have to change something for the cam sensor to get to read correctly? Do they make timing sets to do this?
V Remian
Re: LS1 5.7 camshaft advance
Post by V Remian » Wed May 16, 2018 6:54 pm
No. Yes.
Scotthatch
Post by Scotthatch » Wed May 16, 2018 7:51 pm
OK thanks.... I'm a old man on a steep learning curve to catch up after 10 years off
V Remian
Post by V Remian » Wed May 16, 2018 8:41 pm
I assume your doing this in the chassis, in which case I think it's easier to use offset bushings in the cam gear rather than remove the oil pump to change the t/c set.
Scotthatch
Post by Scotthatch » Wed May 16, 2018 8:47 pm
Ya ..after looking at photos on line I decided that too ..parts are on the way .... looks like job is all labor but not much different then old gen 1 stuff ... good news is I learn fast
3pedals
Post by 3pedals » Wed May 16, 2018 10:12 pm
What cam? And what turbo?
Where is the ICL now?
Whate are the cam card Ivo, ivo, evo, evc points?
V Remian
Post by V Remian » Wed May 16, 2018 11:33 pm
In a couple aspects its easier- no scraping paper gasket residue off the block and no having to compress the thick rubber front pan seal on gen 1's. :D
Scotthatch
Post by Scotthatch » Wed May 16, 2018 11:36 pm
I am guessing you don't think it should have a problem?
Scotthatch
Post by Scotthatch » Wed May 16, 2018 11:37 pm
That is a real plus
V Remian
Post by V Remian » Wed May 16, 2018 11:55 pm
Modern sealing technology is one of the best attributes of the ls platform in my opinion. The only major oil leak I ever had was when I broke a rod in the water box and pieces of the block landed on the track. That was a pretty good size coolant leak too!
