Too much would be when the top ring comes out.sccagt1racer wrote: ↑Wed May 16, 2018 6:34 pm I'm assembling a ls engine for a friend and from my calculations its going to be .012 -.015 out of the hole. I have a .051 head gasket right now and could go thicker if needed. How much is too much out and what is the min quench I'll be safe at. Ive been told .038 -.040. Its a ls6 with a wiesco forged piston. wiesco 6.125 rod and stock crank. Its going to see a max rpm of 7200 road race car.
Max out of the hole
Re: Max out of the hole
- New Member
Being out of the hole is not a problem any more. The block was over bored by the machine shop and is now scrap. Thanks everyone.
Connecting rods, crankshafts, wrist pins, and pistons do not stretch but is a certain amount of deflection to be considered? Depending on component weight, and centrifical forces of the RPMs? Or would this deflection be negligible?
so trueHeadguy wrote: ↑Fri May 18, 2018 1:28 amToo much would be when the top ring comes out.sccagt1racer wrote: ↑Wed May 16, 2018 6:34 pm I'm assembling a ls engine for a friend and from my calculations its going to be .012 -.015 out of the hole. I have a .051 head gasket right now and could go thicker if needed. How much is too much out and what is the min quench I'll be safe at. Ive been told .038 -.040. Its a ls6 with a wiesco forged piston. wiesco 6.125 rod and stock crank. Its going to see a max rpm of 7200 road race car.
In any material stress results in strain, however little. That said, squish change from static cold to dynamic hot is the cumulative result of the thermal expansion of the block, crank, rod and piston (from pin bore to crown) plus possible piston rock and the inertial loads on the moving parts. Going too tight can sometimes be deduced by a sudden increase in blow by above some RPM limit, as the top rings are unloaded by the pistons striking the head.B Original wrote: ↑Fri May 18, 2018 6:47 am Connecting rods, crankshafts, wrist pins, and pistons do not stretch but is a certain amount of deflection to be considered? Depending on component weight, and centrifical forces of the RPMs? Or would this deflection be negligible?
Built a 472 cid sbf 6.400 rod/ 4.250 stroke. She's WAY out of the hole. Lol. .120 cometic.
Does anybody taper the top land slightly to stop scuffing on the change of piston direction?
Tony
Tony
If the piston was 3.0" tall and the skirt clearance 0.005", the maximum 'tilt' would only be 1/10th of a degree, so the top of a 0.300" high land would only come about half a thous. closer to the wall than the bottom.
The reduced top land diameter to accommodate expansion due to the possible ~ 500°F. crown temperature is usually quite generous*, so, no. (*The resulting crevice volume is a discussion-worthy topic.)
