Calculating CFM used from Dyno sheet ?
Stan Weiss
Vendor
Re: Calculating CFM used from Dyno sheet ?
Post by Stan Weiss »
hoffman900 wrote: Sun May 20, 2018 7:11 pm
Well, this is pretty typical of what is (was?) used in Australian V8 Supercars:
Bob,
Unless I am looking at the wrong thing. Would you know why the different injector locations fro each bank?
Stan
statsystems
Post by statsystems »
SchmidtMotorWorks wrote: Sun May 20, 2018 11:55 pm Here is how it plays out in a tunnel ram
Jon,
what happens when you change the firing order on this sim with a 7-4 swap, and then the LS firing order (which is really a Cadillac firing order)? Can you run that?
hoffman900
Post by hoffman900 »
Stan Weiss wrote: Mon May 21, 2018 11:44 am
Bob,
Stan
I think it’s just an optical illusion. They look the same to me.
-Bob
DrillDawg
Post by DrillDawg »
Scotthatch wrote: Mon May 21, 2018 11:41 am OK ... I have not done car stuff for 10 years as I was to sick and only been here a short time so still getting the lay of the land
Glad your doing better.
BORN RIGHT THE FIRST TIME
Scotthatch
Post by Scotthatch »
OK I ran the numbers on the OP engine using the ram effect calculation I hope it is readable ...rpm comes out to 6887 rpm .... if the plenum is reworked the runner length could be 1/4 shorter or a few rpm higher ... the better the data you put in the more accurate the number will be ........
DrillDawg
Post by DrillDawg »
On page 8 I can up with 6945rpm.
Scotthatch
DrillDawg wrote: Tue May 15, 2018 7:16 pm RPM at peak Horsepower....
(2000/64.5)x 224cfm (375cfm converted from 28" to 10") = 6945rpm
Now I know where it came from.... the manual for the basic flowbench from superflow .... I got one from them when I was looking at benches in the 80's .....
The one I used should be more accurate as it uses more data rather than a constant
vannik
Post by vannik »
Not sure if this is from the same engine - Australian V8 Ford from mid 2000's.
Shows that at 4992rpm there is 3 waves and at 7444rpm 2 waves. Measured compared with simulated.
“Ignorance more frequently begets confidence than does knowledge.” -Charles Darwin, The Descent of Man
Scotthatch
vannik wrote: Mon May 21, 2018 1:43 pm
Pressure measured where in the runners?
vannik
Post by vannik »
I do not remember but the sim was adjusted to measure at the same place - it was in 2005 and I am not supposed to publish these but after 13 years and a rule change or two and the team changed engine manufacturer I figured it should be ok.
hoffman900
vannik wrote: Mon May 21, 2018 2:43 pm I do not remember but the sim was adjusted to measure at the same place - it was in 2005 and I am not supposed to publish these but after 13 years and a rule change or two and the team changed engine manufacturer I figured it should be ok.
Neels,
That’s what the file name said it was. Thanks for posting those graphs!
-Bob
hoffman900
Also I made this some time ago. This is % change over a baseline (right click, open in new tab for a better view).
This is just adjusting total intake tract length. You can see how it comes in and out of tune.
-Bob
Scotthatch
Post by Firedome8 »
Smokey
