Calculating CFM used from Dyno sheet ?
hoffman900
Re: Calculating CFM used from Dyno sheet ?
Post by hoffman900 »
Stan Weiss wrote: Sat May 19, 2018 1:42 am
hoffman900 wrote: Fri May 18, 2018 7:55 pm
Stan Weiss wrote: Fri May 18, 2018 7:48 pm Thanks for the full picture. It is what I believed. 0 to 720 / 2 full crank rev / one complete cylinder cycle. So 640 would be BDC. 630 = 10 BDDC 624 = 16 BBDC
Stan
Stan,
That's my graph. Let me know what you want to see I can I pull up some. Numbers, wave directions, etc.
Also, It doesn't always cross zero at the same point.
Bob,
At what RPM is that and what RPM is Peak HP?
Stan
Stan, 7000rpm and 7000rpm
-Bob
n2xlr8n
Post by n2xlr8n »
randy331 wrote: Sat May 19, 2018 1:28 am
Scotthatch wrote: Fri May 18, 2018 3:16 pm I think the pulse thing may be a joke
Pulses are a Joke ??
I had one that had a dip at 7000 rpm. A few cams, a couple intakes with work on them more than once, 3 sets of heads on it, 2-3 collectors on the headers,..lots of dyno pulls over 8-10 dyno sessions, a few carb spacers, 3-4 different carbs. That stubborn power dip stayed there.
Then switched out my headers for a set the dyno shop had hangin on the wall,.... and power dip gone.
Same primary pipe diameter.
What did away with the dip if it wasn't waves ?
Rhetorical statement, I know.
But to the OP, pressure waves are certainly not a joke.
Most of my career has been focused on waves of some sort.
I used to show these vids to students having trouble with the function:
https://www.youtube.com/watch?v=BWraEDaVXZM
Warp Speed
Post by Warp Speed »
n2xlr8n wrote: Sat May 19, 2018 6:50 am
Pretty cool vid!
groberts101
Post by groberts101 »
What I don't understand is how someone could be so well versed in engine theory and design yet not believe in wave tuning? Seems highly counter-intuitive in the scheme of what goes on inside a constantly moving uni-directional mass and exploding combustion engine.
Ever see fuel standoff above a carb or injector trumpet? The power of multi-directional waves combining to create standing waves can easily levitate those small droplets of fuel.
So even testing same tube diameter headers.. subtle changes in bend radius and number of bends along with slight length variations can cause different reflected wave tuned results that Randy is pointing towards here. Very real phenomena and extremely well studied for the last hundred years or so.
Tons of vid's out there showing sound wave levitation capabilities over solid objects much heavier than air. I had a few good ones saved on my other downed hard drive but I will see if I can recollect their names and post them up here.
EDIT: Turns out my memory is horrible.. been too long and search parameters are obviously everything when it comes to finding things on the net. Here's a couple of decent ones though.
Since everybody loves slo-mo vids... https://www.youtube.com/watch?v=0K8zs-KSitc
Another using smoke to show half length standing waves... https://www.youtube.com/watch?v=XpNbyfxxkWE
swampbuggy
Post by swampbuggy »
Uni-directional-----i can not for the life of me believe other than, at 9000 RPM's the air/fuel mixture is moving "MOSTLY" one direction----towards the cylinder. ???????? Mark H. :D
DrillDawg
Post by DrillDawg »
The pulse or wave just provides a low pressure area at the valve when timed right just like in the exhaust.
BORN RIGHT THE FIRST TIME
n2xlr8n
Post by n2xlr8n »
groberts101 wrote: Sat May 19, 2018 10:23 am
Or the pulses exiting the zoomies on a TF FC at night....the pulsed RF waves (with E and H fields) accelerating an electron to 99.997% of the speed of light...two sound sources out of phase, algebraically cancelling or adding a phase shift to the sound our brains register, etc.
Waves are cool :wink:
Stan Weiss
Vendor
Post by Stan Weiss »
hoffman900 wrote: Sat May 19, 2018 6:24 am
Stan,
Bob,
Stan
Bob,
Thanks. If it is not a lot of work can you produce another one of those at what will be the RPM you shift at?
Stan
hoffman900
swampbuggy wrote: Sat May 19, 2018 10:36 am Uni-directional-----i can not for the life of me believe other than, at 9000 RPM's the air/fuel mixture is moving "MOSTLY" one direction----towards the cylinder. ???????? Mark H. :D
I'll post lots of graphs later on at both peak hp and peak torque. Have stuff to do..
In the meantime..
Jon Kaase's clear manifold:
https://www.youtube.com/watch?v=7Iq1B-2paCs
Renault Formula One engine dyno (circa 2006):
https://www.youtube.com/watch?v=y2iBbwocYZw
Harley horsepower shootout winner:
https://www.youtube.com/watch?v=pvECwI7ODwE
Stan Weiss wrote: Sat May 19, 2018 10:41 am
Bob,
Stan
Bob,
Stan
Stan, I accidentally overwrote that file, but I produced a new file (slightly different exhaust) while eating breakfast this morning. Does peak hp and peak torque work? I have most of them saved, just need some time to post them up and type a key.
-Bob
groberts101
n2xlr8n wrote: Sat May 19, 2018 10:38 am
Yep.. almost mentioned those too but my posts tend to get long enough as it is. :lol:
What about shock wave diamonds too!
https://goo.gl/images/H5tpKv
https://www.youtube.com/watch?v=swoCdEwbFRc
I love this kinda stuff too.
PS.. sorry for the tangent but if you think hard enough about its potential effects.. this stuff can surely affect "CFM used from the dyno sheet".
Stan Weiss
Vendor
hoffman900 wrote: Sat May 19, 2018 10:44 am
In the meantime..
Bob,
Stan
Bob,
Yes, that should work.
You need a better data back up system. I have an external hard drive that I can hookup and use about once a month. But I always have a USB thumb drive plugged in and back what I am working on to there at least one a day.
Stan
Scotthatch
Post by Scotthatch »
Wow you guys take one little comment a guy makes and go screaming off into right field .......
I was not talking about any of the stuff you guys posted but now I guess we have three subjects being discussed in this thread....
My problem is with this page from the superflow manual
In a lot of ways this conflicts with the ram effect page that I made work
If you looked back at my posts you will see I did have the reflective wave listed in what is going on in the runner and like anyone that has work on motors a long time I have seen standoff above the carb .. my problem is in pinning down HP produced by this that is not also in the ram effect calculation
Scotthatch
In my current view of how it all works I think there is a standing wave in the runner created by the opening and closing of the intake valve and the frequency is dependent on the rpm and this standing wave moves with the column of air fuel into the cylinder following the basic ram effect calculation ... if you look at the video of the running cylinder you can see the pulsing because I think the fuel somewhat sits in the waves like the balls ...
The other thing to note is as a runner gets longer if you don't leave the valve open latter the standoff gets worse which suggests that the energy that is generated by ram effect is higher as the runner gets longer and so the reflective wave is stronger unless you use the energy to fill the cylinder....
DrillDawg
Post by DrillDawg »
2nd pulse is the strongest, but the longest, 4th the weakest, but the sbortest, each time it gets weaker.
Warp Speed
Scotthatch wrote: Sat May 19, 2018 12:35 pm Wow you guys take one little comment a guy makes and go screaming off into right field .......
It IS the ram effect!
