pushrod length help
77cruiser
Re: pushrod length help
Post by 77cruiser » Sat May 12, 2018 11:06 am
I'm thinking Profilers have .1 long valves too & the pattern up nearly dead center, with Scorpion rockers.
Wonder if they put the rocker studs in the wrong place?
Jim
GOSFAST
Post by GOSFAST » Sat May 12, 2018 5:21 pm
Haven't seen the video mentioned but personally I don't put too much faith in any videos due to mfr's tolerances!
If you choose 10 different brands of rockers you'll end up with at least 6 different valve tip patterns, maybe even more, been there many times.
Don't have all the OP's specs but he should be somewhere between 7.000" and 7.300" on the pushrod lengths, assuming this is a conventional 23* retro-hyd roller SBC build? Largely depending also on the brand of lifters used! There's approximately .200" difference in the pushrod seat cup hgts between some brands of lifters!
Thanks, Gary in N.Y.
P.S. I can give you one "positive" over here, we will not build any more units using the Scorpion line, had many headaches over time with this particular brand! This is my own take on them, right or wrong.
Jan. 2016 - New York Street Ride 7.56 @ 190 @ 3800#
(https://www.google.com/url?sa=t&rct=...12064104,d.cWw)
smokie
Post by smokie » Sat May 12, 2018 10:39 pm
here is what i have, if you need more info just let me know.
the heads are assualt/proheader,nkb200 dart copies. +.100" longer valves. the rockers are scorpion 1.5 roller rockers for 7/16's studs. the block has been decked to 9.005". the cam is XR294HR-10. Duration @ 0.006": 294° / 300°, Duration @ 0.050": 242° / 248°. Max Lift w/ 1.5RR: .540" / .562". the lifters are lunati street retrofit hydraulic roller lifters.
using the mid lift method, it calls for a 7.65"pushrod. a 7.200" (factory vortec) centered the sweep, but it was about an 1/8th inch wide.
steve cowan
Post by steve cowan » Sun May 13, 2018 12:48 am
Gary,
i have a set of 1.6-1.5 Scorpion rockers on a set of cast dart sportsman 2s
i had to machine a chamfer on the base of the posilocks as they were touching the inside of the rockers at TDC.also it looks like the case hardening is starting to wear off the roller tip,FT solid cam 327sbc hase not done a lot of work.
i don't want to bash the BRAND but i am curious with your findings,
thanks
steve c
steve cowan
Post by steve cowan » Sun May 13, 2018 1:25 am
smokie wrote:
Fri May 11, 2018 9:16 pm
the heads are assualt/proheader,nkb200 dart copies. the rockers are scorpion 1.5 roller rockers. the block has been decked to 9.005". the cam is XR294HR-10. Duration @ 0.006": 294° / 300°, Duration @ 0.050": 242° / 248°. Max Lift w/ 1.5RR: .540" / .562".
how can i make sure the lifters are pumped up? i guess i need to use checker springs as well.
thanks everyone
smoke,
sometimes you cant always find a perfect sweep and centre of valve,i have had a few engines i have run off centre slightly to the exhaust side of the valve,my 383 sbc with 680''solid roller with 1.6 rockers 230-600 on the nose is an example of that,12 months of street driving and track twice a month to 7600 rpm,just had heads cleaned up and seats and valves done,guides are still good,
i think you might find as well that most pushrod companies offer pushrods in 0.050''
increments unless you go custom made,dont quote me on that one but when i look at a online listing for pushrods that is what they offer,comp,CV to name a couple,trend might be different as i have never delt with them.
i think you will find it difficult to try and use a hydraulic lifter without a soft checking spring as the lifter will collapse and give you a false reading.
steve c
tresi
Post by tresi » Sun May 13, 2018 3:03 am
I have heard horror stories of some import heads that had valve guide and rocker arm stud angles all over the place. I have no experience with Assault heads. They may be fine heads but is this a possibility?
smokie
Post by smokie » Sun May 13, 2018 2:00 pm
SPEIER RACING HEADS use them or at least used to. i don't think Q.C. was the reason for the change though.
