Crankshaft welding..
gn69z28
Post by gn69z28 » Wed May 09, 2018 10:05 am
Have a crankshaft that needs welding. We once used someone in I think South Carolina. All they did was cranks but I can't remember who it was. Any ideas? Thanks
gn69z28
Re: Crankshaft welding..
Post by gn69z28 » Wed May 09, 2018 10:30 am
Never mind we figured out who it was.
mag2555
Post by mag2555 » Wed May 09, 2018 12:06 pm
What needs to be done to the Crank?
Charliesauto
Post by Charliesauto » Wed May 09, 2018 1:13 pm
Spartanburg Crankshaft in Spartanburg SC has a good reputation.
We have had very good results with Shaft Tech in Fostoria OH, if you don't mind shipping.
gn69z28
Post by gn69z28 » Wed May 09, 2018 6:19 pm
To answer what needs to be done to the crank. It's a 4 stroke Yamaha outboard crank that someone welded the no 1 rod journal on and did a horrible job. It's out of round by .010 and the welding didn't go all the way to the filets. It needs to have all that ground out and rewelded.
Newold1
Post by Newold1 » Wed May 09, 2018 7:23 pm
For Marine engine crankshafts talk to Marine Crankshaft in Santa Ana, California. David is the top outboard crankshaft man in the USA!
gn69z28
Post by gn69z28 » Wed May 09, 2018 7:38 pm
It's an outboard but it's a 4 stroke. The crank is the same as an automotive crank with the same type of bearings. Completely different than the 2 stroke cranks.
Walter R. Malik
Post by Walter R. Malik » Wed May 09, 2018 7:50 pm
I would call Performance Crankshaft in Royal Oak Township, Michigan ... (586) 549-7557.
mag2555
Post by mag2555 » Thu May 10, 2018 6:14 am
Grinding out bad weld is very labor intensive and costly!
You might want to save yourself some cash and use big Ass electric grinder that you can rent and a 10" abrasive disc to get the job well started for who ever will reweld and grind the Crank.
Newold1
Post by Newold1 » Thu May 10, 2018 7:47 pm
I am very familiar with 4 stoke outboard engines. They are not automotive type crankshafts as most are not 90 degree V-6's or V-8's and are configured and sized quite differently than automotive crankshafts. That's why I recommended David at Marine Crankshaft. Just ask around the high performance outboard engine community and you will have his name and company recommended all over the world more than most.
cgarb
Post by cgarb » Thu May 10, 2018 8:13 pm
No way...take it to who ever is going to do the job and consult them first. You might make more of a mess trying to grind out the last disaster. That's like trying to help out the body man and rough everything in first...usually they grind off all the crap someone else put on and start fresh anyway. Just cost them more work is all.
pamotorman
Post by pamotorman » Thu May 10, 2018 10:48 pm
some crank welding machine use submerged arc welding
ProPower engines
Post by ProPower engines » Fri May 11, 2018 4:38 am
I get the reason behind the weld repair has to be there is no cranks available.
If you can find a shaft it will be better then the 2nd go around welding and regrinding as the heat treatment will need to be done to the complete crank. And if it was done before on just a single journal you are going to invite it to break and the end result will be more costly.
I would do a better search for a crank as we see those engines all the time for repairs and 3 out of 10 the block is junk and good for parts only.
PM me the details with the year model and serial numbers and I can see if the local dealers have any available.
The local dealers here have hugh boneyards full of Yammy stuff cause the parts are costly and they don't want to do these type of repairs unless they have good customers that pay promptly
engineguyBill
Post by engineguyBill » Sat May 12, 2018 12:13 pm
Another vote for Marine Crankshaft in Santa Ana.
Bill
SAE Member (28+ years)
- Theodore Roosevelt
Keith Morganstein
Post by Keith Morganstein » Sat May 12, 2018 1:29 pm
http://www.marinecrankshaftinc.com/outboard.html
