Engine machine shop destroyed my block
Dave Koehler
Re: Engine machine shop destroyed my block
Post by Dave Koehler » Mon May 07, 2018 10:18 am
groberts,
You assume there was an error by a shop of .0015.
If the poster can't write it down correctly it brings in doubt of how it was measured, what with, calibration and the temperature difference.
If it was written correctly then it is much ado about nothing.
John@RED, want to follow up on this so this can be put to bed before it gets more out of hand?
Walter R. Malik
Post by Walter R. Malik » Mon May 07, 2018 10:26 am
John@RED wrote:
Mon May 07, 2018 8:03 am
A wonderful engine machine shop just made the bores 0.00008 to 0.00015 bigger than what I asked:
what can I do now to save the block, except sleeving it, beside asking them for damages?
:evil:
I hope this is a misprint or a typo ... a tenth and a half thou over ...?
groberts101
Post by groberts101 » Mon May 07, 2018 10:33 am
groberts,
Probably much ado about nothing.
As others have also eluded to.. just seemed like a logical assumption since I know of no "engine machine shop" short of maybe an areospace manufacturing facility that could even measure such an infinitesimal number. As also mentioned it would probably need to be measured inside a highly temperature controlled sealed chamber to even come close to that resolution. Not sure.. maybe even a laser based measuring system of some sort?
My apologies if I seemed to say that anyone posting early on was inept in any way shape or form. Was not my intention in the least since guys like you do this stuff for a living and I do it out of a garage based workshop while hanging on longer coattails just to figure it all out. :D
Greg
Warp Speed
Post by Warp Speed » Mon May 07, 2018 11:00 am
tenxal wrote:
Mon May 07, 2018 8:57 am
:evil:
Please describe the measuring process used to determine 80-150 millionths.
Air gauge......
piston guy
Post by piston guy » Mon May 07, 2018 11:33 am
I suggest measuring the piston diameters for variance and placing them to your advantage. I'm sure there is some variance in diameter among them.
ProPower engines
Post by ProPower engines » Mon May 07, 2018 1:28 pm
Before I got bent out of shape about a measurement between your measuring instruments and the shops tools I would do a direct comparison at the same temperature.
I have run into this same issue a few times over the years where a DIY'r that has basic measuring tools tells me to make it a specific number only to find out he has a bore gauge that does not read in 10th's but is guessing as he has a gauge that reads in 1/2's and imagines the between numbers. While it can be close its not perfect.
Not if you have a gauge that reads 10th's as does the shop then calibrate your tool and go back and recheck it.
You may find it may be dead on or not as bad as you think it is. Or it can be worse.
But I would not get to upset at .0005" over what you asked for but more then that I would not accept if you are both working with similar tooling and temp in both shops.
I like to take critical measurements in the morning so the heat of the day does not influence sizing as much before the shop gets heated as well as everything else in the shop.
tjz450
Post by tjz450 » Mon May 07, 2018 2:17 pm
I took the OP's post as total sarcasm, to bait and spool up the membership. May have worked.
John@RED
Post by John@RED » Mon May 07, 2018 3:09 pm
Ah ah, sorry guys for the zero more there.... #-o
I obviously was talking about .0008 - .0015 more than what I asked.
I know it could seem not to be a lot, but in this little engine suggested piston to wall is .0032, so .0015 is about a 50% too much.
As someone wrote in the first page, I was just told by them that heated by the coolant during machining the clearance was ok, and they too see that back to ambient temp the clearance was the same i got:
I know that this may happen in some blocks, but thought .0015 to be too much
ProPower engines
Post by ProPower engines » Mon May 07, 2018 3:25 pm
Well that said more details regarding what engine it is and it's intended usage as well as piston type etc would go along way to getting any help that would be useful in your case.
The omission of the details of it being hot honed changes everything.
That said if you can post what pistons etc. guys that have done similar builds can ad info more helpful.
But if you are checking a block that was hot honed it will change a good amount from heated state to cooled off and the bores in some cases will show up funny sizes at different points in the bore top to bottom.
engineguyBill
Post by engineguyBill » Mon May 07, 2018 3:29 pm
As has been pointed out already in previous posts, the difference between the OP's measurements and the machine shop measurements could very well be attributed to temperature differentials and measuring tool calibration. Personally, I would be more confident in the measurements at the machine shop . . . . . . but, that's just me.
Bill
SAE Member (28+ years)
- Theodore Roosevelt
exhaustgases
Post by exhaustgases » Mon May 07, 2018 3:53 pm
:evil:
Are you using a recently calibrated ring gauge to check what ever device you used to measure the bores? And was the block at the proper temperature to check it. To accurately check to .00008 you would also need an air gauge or a calibrated cmm. Oh and most important once the engine is up to operating temps those bores will be much larger.
Dave Koehler
Post by Dave Koehler » Mon May 07, 2018 4:14 pm
gasses,
Did you read the 3 posts above yours?
tenxal
Post by tenxal » Mon May 07, 2018 4:39 pm
Air gauge......
I hear 'ya. :wink:
No way was I going there..... :lol:
modok
Post by modok » Mon May 07, 2018 8:44 pm
Just in case, you didn't mention....
Was a torque plate used?
Are the skirts coated?
And have you checked the actual clearance comparing skirts to block bore.... or just bore size?
Pistons are getting really good, but I still like to check each one just to be sure.
I;ll assume at worst there could be .0005 difference in measuring due to being a different hand using different measuring equipment, and on a "home gamer" level that could be twice as much. Nothing personal, but it would not be the first time at all.
If the cylinders were heated....they would be larger. They are blowing smoke. But did you buy that? :)
Glen Urban
exhaustgases
Post by exhaustgases » Mon May 07, 2018 9:25 pm
gasses,
No I didn't before posting sorry. :oops:
