Rebuilding ford T&D shaft rockers
createaaron
Post by createaaron »
I have a set of aluminum shaft rockers I got from a circle track racer that seems like it wasn't getting sufficient oil and it galled over half of the rockers bearings.
I have to replace 16 bearings (2 per rocker) and 3 shafts.
My question is, is it worth it to just replace the parts that are damaged? Or does Murphy's law say if I don't replace all bearings they will self destruct on my engine?
Horsepower is a beautiful thing
Scotty
Re: Rebuilding ford T&D shaft rockers
Post by Scotty »
You already know the answer to your question.....one in all in, do the complete set and have peace of mind.
Geoff2
Post by Geoff2 »
Sometimes, depending on shaft thickness & how the shaft is mounted, the mounting bolts are overtightened & distort the shaft. With the shaft no longer being round, the rockers bind up. Not a lubrication issue in this case.
Post by MadBill »
Keep in mind that aluminum rockers, like aluminum rods, have a finite fatigue life; the higher the load the shorter the life. If they've already done thousands of laps with say 700# open loads... :-k
createaaron
It's hard to say how many laps/miles were on this particular set. They're pretty chewed up and I got reamed on this deal with the guy so I'd like to make them work one way or another.
hondo383
Post by hondo383 »
What Madbill said...throw them away.. no telling how many cycles on them
swampbuggy
Post by swampbuggy »
Why not sent them back to T and D, they know best----??? Mark H.
createaaron
Because labor is free when i do it.
cgarb
Post by cgarb »
Replace the 3 shafts and price the bearings for a whole set...if its not terrible replace all the bearings, if not fix what's broke and move on. They break again then buy a new set.
