GM_Chevy_35L_355HP_GDI_12620214 651.0 RWHP
651.0 Chassis Dyno RWHP at 6700-6800 RPM with ProCharger 15.5 Psi Boost
2015 GMC extended Crew Cab Truck
5550.0 Lbs with Driver
stock Converter 2200 RPM Stall
3.42 gears
ProCharger 15.5 psi Boost
Chassis Dyno = 651.0 HP @ 6700 RPM
Dec 11, 2016 4:33PM
Dragstrip
1.831
4.890
7.439 - 96.31 MPH
9.645
11.549 - 117.43 MPH
after new Port work + new Cam Motion Cam specs :
205/219-116 Centers 0.585/0.585 Valve Lifts -VS- original GM Cam Specs = 193/200-113 Centers 0.500"/0.485" Valve Lifts
Out-the-Box Stock Shape Flow Numbers
GDI_12620214 stock 1.932/1.555 Valves
after Rough-Carbide Port Job and Valve Job Flow Numbers
GDI_12620214 same stock 1.932/1.555 Valves
3.42 gears
Dec 11, 2016 4:33PM
Dragstrip
1.831
4.890
7.439 - 96.31 MPH
9.645
11.549 - 117.43 MPH
Re: GM_Chevy_35L_355HP_GDI_12620214 651.0 RWHP
ETA Simulation
Hi Larry,
I assume you meant 5.3L engine. Did you happen to notice this thread showing a cutaway of those heads? http://www.speedtalk.com/forum/viewtopi ... =1&t=50362
I've had some pretty good health issues the last year or so and haven't pursued this project much further. I also anticipate some incredible hp numbers with boost and NA with these port shapes. I really want to work on a set of L86 heads with the larger ports and valves but haven't found a broken one to cut up yet.
-Carl
-Carl
yes i meant 5.3LIn-Tech wrote: ↑Sun Apr 29, 2018 11:38 pm Hi Larry,
i gotta go correct all the FileName now , thanks for pointing out !
and WOW !!! .... awesome sectioned Pictures ... i cannot thank you enough for all those great Pics !!!
i somehow missed that Thread
PS: that's Chris's everday Work Truck
brings all the Engines to Dyno test ... its a sleeper , open the Hood and its very stock looking .
He just Dyno tested a BBC 713cid Sonny Hemi head engine
said a Woman was using her Cell phone taking pics of that engine along Interstate-10
a bunch of people gave him Thumbs Up along I-10
Ahh, now I know where my Mr. Potato Head lips got to...
yeah .... i knowby tt 383 » Sun Apr 29, 2018 11:28 pm
i was in a hurry .. it was either pure White or this nice Red
i went with the Red .
FYI : i retired the Red ... when more of my favorite looking Green-colored Clay sticks came in
PS ; i use GoJo Hand Cleaner ( plain smooth , no Pumice ) to smooth the Clay, and it dries within 1 minute
and as added plus , i can clean off the Clay residue off my Hands before i start typing on the Keyboard on a Flow Test
i wonder why the port flow tests are not done with the intake manifold in place as would not that would be a truer reading
Yes ... that's how i always try to Flow test ... but sometimes the Customer will not bring or want to Port his Manifold/Spacerpamotorman wrote: ↑Mon Apr 30, 2018 8:39 am i wonder why the port flow tests are not done with the intake manifold in place as would not that would be a truer reading
nor bring his Carb either to Flow test as a complete Induction System !
for SuperStockers + Comp Elim
i always make additional Flow tests with complete Induction System
Note: all other Intake Ports have red rags stuffed into them or either theres Valve Springs/Valves seated in the other Cylinders,
and there's clear tape sealing-off the other side of Intake Manifold
Also : i don't like using Clay Radius Entry that much ... i purchased a bunch of 2x6 and 2x8 and 2x10 boards to make wood Radius Entries
I was testing a VicJr.tall on my Dart 215's yesterday and I was using foam to fill other runners. I was not happy with it, I have also used duct tape to seal unused ports. There was a question about flowing with the previous firing cylinder runner open to give a more realistic model. What are you guys using to seal runners and are you flowing through another runner as well? I see Larry said he uses rags, my bench loves to eat stuff like that. Thanks, Charlie
yeah ... but i use a 3/8ths aluminum rod to ram in the red shop rags into only the Cylinder Head's Intake PortsI see Larry said he uses rags, my bench loves to eat stuff like that. Thanks, Charlie
still its potentially dangerous with Shop Rags
way safer to just install Springs/Valves on all the other non-Flow tested Cylinders
Thanks, Larrymaxracesoftware wrote: ↑Mon Apr 30, 2018 3:30 pmyeah ... but i use a 3/8ths aluminum rod to ram in the reg shop rags into only the Cylinder Head's Intake PortsI see Larry said he uses rags, my bench loves to eat stuff like that. Thanks, Charlie
