454SS 230hp remedy
scottcleaver
Re: 454SS 230hp remedy
Post by scottcleaver » Fri May 04, 2018 10:52 pm
pdq67,
cam specs and price please
cstraub
Post by cstraub » Sat May 05, 2018 9:46 am
gnicholson wrote:
Fri May 04, 2018 5:51 pm
Why did you go with that large of split between the intake and exhaust? Was it for a stock exh system? I would think it would have made more torque with a single pattern cam.
It's what the math said it needed. Truck is used to pull race car to track and customer wanted a sleeper. He wanted just a note of cam in the engine and that is all. If memory serves me it ran 13's.
Chris Straub
Performance Mfg.
http://www.straubtechnologies.com
www.distributorgears.com
randy331
Post by randy331 » Sat May 05, 2018 10:28 am
Why would it make more TQ with a "single pattern cam" ?
If the cam was 221/221 would it make more TQ ?
Why would the best valve events turn out to be a single pattern cam ?
77cruiser
Post by 77cruiser » Sat May 05, 2018 12:31 pm
How bout 209/209? 8)
Jim
randy331
Post by randy331 » Sat May 05, 2018 2:53 pm
I'd bet on 221/221 producing more out right TQ. 209 isn't enough duration to produce max TQ, but that doesn't mean 209 isn't a better choice for the application in this thread.
But I still don't agree that more ex duration cost TQ. Not enough ex duration would cost you tq too wouldn't it?
gnicholson
Post by gnicholson » Sat May 05, 2018 4:51 pm
Im sure chris straub knows a ton more about cams than i do. Its just in my experience a smaller single pattern cam on 108 will make more low rpm torque than a cam with a 10 deg split but thats assuming the exhaust is up to the task plus if the tbi is retained to much overlap will cause issues. I was just asking mr straub what his thoughts were
scottcleaver
Post by scottcleaver » Mon May 14, 2018 7:12 pm
So, after a good amount of responses, thank you. I have narrowed it down to two options. Rebuild the bottom end either way but the top end goes two completely different directions. Most important to me is not getting the budget issue cloudy like i always do.
1. Cam thats an every day driver and happy on vacuum, set of the Ebay cheap ass aluminum heads (yea I know how that sounds), set of pistons to match the heads and keep it at 9.2 to 9.5 compression and an aluminum intake. Aftermarket Holley TBI self learning system and headers.
2. Single Turbo kit with a cam and pistons to match. Valve job on the existing heads and an aluminum intake with a Holley TBI setup and set the boost to 7-8lbs. I have not run a turbo before and its kind of got me interested
Thoughts anyone, and thanks again for suggestions
Thanks Scott
