.003 rod clearance
1972ho
.003 rod clearance
Post by 1972ho »
What oil viscosity would you all recommend with rod bearing clearance of .003 and the mains at .0025-.0027 running a dry sump system.
Abbottracingheads
Re: .003 rod clearance
Post by Abbottracingheads »
Anything you want. It will be fine.
Warp Speed
Post by Warp Speed »
.003 rod bearing clearance?!? :shock:
What is the application?
1972ho
Post by 1972ho »
Drag racing I’ve been using 10w30
statsystems
Post by statsystems »
1972ho wrote: Wed Apr 25, 2018 4:10 pm Drag racing I’ve been using 10w30
I think warp wants to know what the engine is. That's plenty loose unless you are dealing with big throws and mains.
cjperformance
Post by cjperformance »
1972ho wrote: Wed Apr 25, 2018 12:39 pm What oil viscosity would you all recommend with rod bearing clearance of .003 and the mains at .0025-.0027 running a dry sump system.
I'd start at 20 to 23 Cst at your oils race/operating temp.
1972ho
Post by 1972ho »
Warp it is ford SVO v-6 273 cid one reason I ask about the oil viscosity is sometimes I don’t have time to get the oil up to at least 150 because of of the dry sump and I was thinking I might need a lighter oil.
modok
Post by modok »
2" shaft and bearings have a lot of eccentricity then .003 is very loose.
3" shaft and bearings have zero eccentricity then it might even be too tight.
Newold1
Post by Newold1 »
If that is really your rod clearance in that smaller journal size engine I think myself and few others here would think you might be better off using a set of +.0005 to .001 bearings and tightening things up just a bit.
Old School
Post by Old School »
The clearance is fine for drag racing. 10-30 10-40 either will work well.
