Rod side clearance
Rod side clearance
Building my 421 shortblock, got everything mocked up to grind clearance on the rods for the cam lobes and I checked my rod side clearance and it is at .026" on the two journals that I checked. Does this seem excessive? I assume there is nothing that can be done about it short of buying another crank or different rods.
Re: Rod side clearance
thats .026" divided over 3 points of clearance, about .008" and a bit per clearance point you have no problems. This is oil exit area for the big end bearings, there needs to be enough area to allow enough flow.cgarb wrote: ↑Sun Apr 22, 2018 8:08 pm Building my 421 shortblock, got everything mocked up to grind clearance on the rods for the cam lobes and I checked my rod side clearance and it is at .026" on the two journals that I checked. Does this seem excessive? I assume there is nothing that can be done about it short of buying another crank or different rods.
I found a spec online somewhere for factory type SBC specs and it was .010-.020" my .026" was out of that spec so I was just asking to be sure I wouldn't have any issues with that. Taking my time, checking all my clearance's so I can hopefully have an issue free racing season...well late start to a racing season...lol.
Have you ever heard the saying---a little loose, nobody knows. Too tight, everybody knows (when she self destructs) ? David Reher of Reher Morrison Racing engines stated, my feelings on engine clearances in pretty simple i would much rather it be a little loose than on them tight side. Mark H.
Yes, I have heard that before...I'm a machinist by trade and a bit OCD when building engines. I can't help it... Thanks for the advice. Do you think I could make a .008" thick shim to put between the rods?....just kidding.
I remember that thread and the issues about excessive oiling...that's not my issue here. I was just concerned about the mechanical ability of excessive clearance keeping the rods 90 deg to the crankshaft. My pistons are not guided at the top so I was worried about one of my rods deciding to take a stage right outside the block. That seems to be not an issue with the general consensus so I'm going to continue on with the build.
The old rule of thumb for connecting rod side clearance is 4 times the bearing clearance, minimumcgarb wrote: ↑Sun Apr 22, 2018 8:08 pm Building my 421 shortblock, got everything mocked up to grind clearance on the rods for the cam lobes and I checked my rod side clearance and it is at .026" on the two journals that I checked. Does this seem excessive? I assume there is nothing that can be done about it short of buying another crank or different rods.
I don't think you will see any issue.
