Ported 2970 Edelbrock
I thought I would just post how I port up a basic 2970 for an average 7400rpm 434 bracket engine.
This may take me some time to post the pics and explanations as I don't live on the internet like some of us do.
Re: Ported 2970 Edelbrock
Here's finished before cleaning
Do you bias the 5-7 divider. If you don't what is your thoughts for and against?
Starting with the basics.
I work the flange area back opening the plenum.
Determine length and taper of Runner.
Determine port location.
Rough out the gasket area, and work into the plenum
Tootsie stamp, wash, send it.
Post by cspeier » Sun Apr 22, 2018 8:26 pm
What do you charge for something like this?
Not enough .. i'll bet
MTENGINES ...... Very nice Porting !
Very nice work. I too am curious of cost. PM would be good.
I like how you kept the cross section at the bottom of the port entry small to aid in "lifting" the fuel dropped out of suspension, basically lifting the "mass".
-Carl
-Carl
Looks nice Matt. Did you alter the taper at all?
I like it looks good.
Eric Weingartner
Weingartner Racing LLC
918-520-3480
www.wengines.com
918-520-3480
www.wengines.com
Thanks guys. Sorry for late replies. Been putting in lots of hours. You know how it is.
Most often I just make the path as straight as possible and correct the length the best I can. Do what I can to size the plenum. Etc. I don't want to go into too much detail. But just looking at it you may see what I've done.B Original wrote: ↑Sun Apr 22, 2018 8:22 pm Do you bias the 5-7 divider. If you don't what is your thoughts for and against?
Thanks. You are right. Never enough. Haha.maxracesoftware wrote: ↑Sun Apr 22, 2018 10:59 pm
