Yes Bill they do (and Hilborn too), but very pricey!
Individual runner intake manifold for big block Chevy
Re: Individual runner intake manifold for big block Chevy
That dollar sign is not a typo...
Gene Berg in Calif used to race VWs & he made 58 & 62mm versions of the Weber IDA carbs, & they take the Weber jets, E tubes etc. They would certainly work on the BBC, may still be available.
The factors to consider when sizing itb's (which is more unforgiving than a regular carb) are :GRTfast wrote: ↑Thu Apr 19, 2018 3:46 pm I was reading about the advantages of the individual runner Hilborn electronic fuel injection system. Mainly the fact that with a large cam, you don't get the fouling of the intake charge from overlap that you get with a common plenum intake. Some of the dyno plots show huge advantages in the low end and midrange. Since the Hilborn unit is way out of my price range (8-9k), I was thinking of building my own side draft style intake with individual runners. I would probably use a motorcycle carb on each runner (something like the carbs off late 90's 1000cc sportbikes). I see that this is somewhat popular on small 4 cylinder British sports cars, but I don't see anyone doing it on big V8's. Anyone have any experience with this type of setup? Thoughts on why it is or is not a good idea? Sometimes I get the urge to build something different and make it work. This is one of those times.
- rpm range
- distance from throttle to valve.
- anticipated HP
https://www.jenvey.co.uk/support/faqs/n ... t-in-nisi/
GTRfast:
Go to Ebay item # 292035292135 and for $2400 including free freight and buy a complete IR electronic Fast fuel injection unit. Put it on the engine , have fun learning tuning and tune it, put the engine in your car or truck. Then go drive or race the thing and have some real fun!! Don't punish yourself building a "goldberg". You be much happier when you do and you are driving and using it! JMHO
That looks pretty slick. The thing is, sometimes I enjoy punishing myself!Newold1 wrote: ↑Fri Apr 20, 2018 9:32 pm GTRfast:
I guess with that setup you mentioned, I’d have to build a cover for the valley and connect the water passages to the radiator. Could be a cool option.
Take the risk of thinking for yourself, much more happiness, truth, beauty, and wisdom will come to you that way. -Hitchens
