Poll - Short Turn Curve Bowl Perspective
maxracesoftware
Vendor
Re: Poll - Short Turn Curve Bowl Perspective
Post by maxracesoftware »
cspeier wrote: Fri Apr 20, 2018 1:11 pm These have came in very handy over the years! They have been through a lot over the years! :)
foxchassis wrote: Fri Apr 20, 2018 4:34 pm Image
These are posted over on Larry M. site. One thing missing is a piece of 1/8" solder that wraps around STR /floor
in order to trace over on to alum. I use stiff stencil cardboard then sometimes transfer to .040" alum.
Pic's look nice Chad, Larry :)
Carnut1 wrote: Sat Apr 21, 2018 8:40 am Larry, love to see pictures of your work. I did a bit of research on what kind of flows you get out of that old iron. Super impressive, nice work.
Chad and Dwight ... great Porting Tool Pics 8)
Thanks Carnut1 ... i'm impressed with all your Porting Pics ... thanks for all the Porting pics/Data you've Posted !
here's LED Lights i tested in the next Posts
MaxRace Software
https://www.maxracesoftwares.com
maxracesoftware
Vendor
here's Daylight 5000 K = LED Lights i tested in the next Posts
sort of cheap WalMart brand name = "Great Value"
100 Watt replacement uses 16 Watts
DAYLIGHT 5000 K
packaged a little loose/flimsy.. but no broken bulbs ... gives off very nice bright light , reduced shadows
MaxRace Software
maxracesoftware
Vendor
Home Depot 's Daylight 5000 K = LED Lights i tested in the next Posts
the "BEST" LED type Bulb i found + tested so far :D
Ecosmart 1001 654 075
100 Watt replacement uses15 Watts
DAYLIGHT 5000 K 1680 Lumens
gives off the brightest white light , reduced shadows
MaxRace Software
maxracesoftware
Vendor
awesome light-weight "BEST" LED type Bulb i found + tested so far :D
this is a super light-weight Flood Light or Spot Light to aim bright Daylight at object
Ecosmart 1001 654 087
120 Watt replacement
DAYLIGHT 5000 K 1260 Lumens
you can put this Spot Light in a GooseNeck Fixture
and its so light , gravity will not bend the GooseNeck 8)
This big Spot-Light is lighter than the LED Bulbs in the 2 Pics above ... awesome technology
MaxRace Software
cv67
Post by cv67 »
There are places on ebay that sell 6? in long flexible LED strips, handy for sticking down a port. Makes a noticeable difference (esp if its a long runner)
LCaverly
Post by LCaverly »
I look at the short torn with #2 but with face of head almost vertical establish short turn with piece of solder and then find largest radius that will not lower the floor and still meet parallel with the throat. I also do several operations on the bridge port before I lift a burr, put a rod in push rod hole and touch off that then move over .050 or so and mill pushrod pinch also do same on head bolts, takes time but saves hands and helps me keep ports consistant. also establish throat and seat with cutter before I start with burr.
Len C
mag2555
Post by mag2555 »
If you don't have CNC like me , then a adjustable seat cutter make for a good way to start off with Throat enlightenment.
Once the cutter stops removing meat on the short turn area you have saved yourself a ton of mind boring work!
user-17438
Post by user-17438 »
Here's one I made barely works anymore.lol
Carnut1
Post by Carnut1 »
maxracesoftware wrote: Thu Apr 19, 2018 3:23 pm this is how i'm looking + Porting the Intake Short Turn Curve
this is how i'm looking + Porting the Exhaust Short Turn Curve
Larry, I don't recognize that head. Is that a w2? Thanks, Charlie
P R S
Post by P R S »
Looks like an LS head to me.........
Penrod Racing Services -Walters,Oklahoma--580-591-1947
maxracesoftware
Vendor
P R S wrote: Tue Apr 24, 2018 8:13 pm Looks like an LS head to me.........
yes its a LS1 SBC Head
MaxRace Software
Carnut1
Post by Carnut1 »
It clicked as soon as I read it. Thanks!
