How to move peak horsepower higher?
johnef
Post by johnef » Mon Apr 16, 2018 1:04 pm
Im building a 1098cc gsxr1000 (4mm overbore). The factory head has 30mm Titanium intake valves, and 24mm titanium exhaust valves, 44mm throttlebodies.
Factory cams are 0.370" intake and 0.350" exhaust.
I have figured looking through several motorcycle specifications that intake valve area represents 33.5% of bore area on average. That would put new valve size at 31.5mm.
Would it be correct to base my new choke point of 88% based on the new hypothetical valve size? Even though i will keep the intake valve size at 30mm. It being potentially valve limited would it be better to move choke point closer to valve to maintain diverging angle?
I was looking to push peak horsepower from 12500 RPM to 13500 RPM,what would be the best way to accomplish it? Port length, port taper, camshaft duration?
Walter R. Malik
Re: How to move peak horsepower higher?
Post by Walter R. Malik » Mon Apr 16, 2018 3:19 pm
I would shorten the intake runner length some and make the exhaust pipe slightly larger.
englertracing
Post by englertracing » Mon Apr 16, 2018 3:26 pm
Agree on shorter intake and bigger headers,
Can you put more Cam lift and a touch more duration
johnef
Post by johnef » Mon Apr 16, 2018 4:44 pm
Would enlarging from choke point and all the way back to throttle blade aid in shifting power? And from throttle blade to the velocity stack? I have an existind sidewinder. Could i shorten the first step and leave CSA alone?
I can have cams ground to whichever spec i want. What are the recommendations?
Desertrunner
Post by Desertrunner » Mon Apr 16, 2018 5:24 pm
John would you happen to have any flow bench numbers for the heads? I would be interested to do some maths on them.
