SBC 383 500ft/lb torque build
gottago
Re: SBC 383 500ft/lb torque build
Post by gottago »
That is likely as good as it gets. Nothing wrong with 475 tq at those revs unless you have an unrealistic number stuck in your head and clouding your vision. I would have liked a wife that looked like Raquel Welsh too but had to settle for a little less. :)
CamKing
Post by CamKing »
If you want a lot of torque, you can always drop one of these in it. I made the prototype cams for it.
https://cumminsengines.com/nissan-titan
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
Orr89rocz
Post by Orr89rocz »
77cruiser wrote: Mon Apr 16, 2018 9:00 pm Don't think it will happen, unless you have more ci.
https://www.speed-talk.com/forum/viewtopic.php?f=1&t=43195
Remember this one?
Yes and thats a fairly short runner intake. I would seriously try a big long tube tpi runner with a good head like he had and i bet it makes atleast that torque and possibly more and lower rpm
FC-Pilot
Post by FC-Pilot »
CamKing wrote: Tue Apr 17, 2018 2:30 pm If you want a lot of torque, you can always drop one of these in it. I made the prototype cams for it.
Back when it was pitched to Toyota? They passed because they thought it would never work. They are kicking themselves now. LOL
Paul
Orr89rocz
Post by Orr89rocz »
https://youtu.be/pfo_Dh7VbAs
This one made 494 lb ft.
Several other magazine tests of tpi 383’s had torque values as high as 533 lb ft. Those may be inflated but they flat out produce torque with 18-22” long runners
CamKing
Post by CamKing »
FC-Pilot wrote: Tue Apr 17, 2018 3:06 pm
Paul
Actually before that(2007). It was originally going to go in a Dodge, then the economy tanked, and it got shelved. They pitched it to Toyota, and they balked. Finally Nissan went with it, but they had to redesign the frame to handle all the torque.
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
CamKing
Post by CamKing »
Orr89rocz wrote: Tue Apr 17, 2018 3:07 pm https://youtu.be/pfo_Dh7VbAs
Take all the results you see on youtube, and in magizine's and multiply them by .9
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
xanadu
Post by xanadu »
Ha Ha!!!! Well said.
Orr89rocz
Post by Orr89rocz »
CamKing wrote: Tue Apr 17, 2018 4:19 pm
Idk about that lol i have vids on youtube that are real, one using your cam lol
Mags i can see some inflated numbers but from everything i have seen in the long runner tpi world, i feel its your best bet for getting near that torque number
Throttles performance (900HP on this forum) also did a 400” motor for a boat and it had a miniram intake which has 3.5” runners. It made 500 hp and 500 lb ft torque on engine dyno as well on pump gas. It was a very mild setup. I think a 383 with higher end compression for the fuel and the long runner tuning effects would get close being only down 17 cubes
HDBD
Post by HDBD »
But hot rod and towing don't mix. That's why a sleepy 454 will do so much more reliable miles towing than a stressed 383 pumped to make the same tq
FC-Pilot
Post by FC-Pilot »
CamKing wrote: Tue Apr 17, 2018 4:09 pmActually before that(2007). It was originally going to go in a Dodge, then the economy tanked, and it got shelved. They pitched it to Toyota, and they balked. Finally Nissan went with it, but they had to redesign the frame to handle all the torque.
Interesting, I did not know that it was pitched to Dodge before it was pitched to us. Learn something new every day.
I have been getting a kick out of this thread as it is right up my alley. I will be putting a 412 SBC on the dyno in a few weeks that will be going in my brothers Blazer and I would love to see even 475 Ft/lb's at a reasonable RPM (not huge numbers, but I would think they should be reasonable and doable). If it lacks like it did with the last cam then we are going to rethink the heads and intake.
Paul
GARY C
Post by GARY C »
Or turbo charge the 383.
ptuomov
Post by ptuomov »
If one wants low rpm torque, the very long runners of the TPI intake is going to be very beneficial. As long as one is comfortable with fuel injection, I think that’s a logical direction for a high torqu low rpm engine.
Put Search Keywords Here
NewbVetteGuy
Post by NewbVetteGuy »
Links to the blasphemous dyno results:
534 ft lbs @ 4,700 383 w L98 Heads & TPI intake extrude honed: http://www.superchevy.com/how-to/engine ... induction/
Note: There's nothing cost-effective about this build; they put like $1,000 worth of silly putty through the intake alone.
501 ft lbs 383 @ 3,900 AFR Heads & TPI intake: http://www.powerperformancenews.com/tec ... -upgrades/
NewbVetteGuy
RCS Racing Engines (an Engine Masters participant) has a 383 SBC Crate Motor for sale using the FIRST Fuel Injection long-runner intake and claims it makes 520 ft lbs @ 4,000 RPM, too. So even the "inflated magazine #'s" camp has to contend with RCS Racing's currently for sale 383 making over 500 ft lbs... The long runner intakes seem to break the rules-of-thumb (that "3 PSI supercharger" that operates at the torque peak on them seems to do its job).
http://rcsracingengines.com/Perf%20Crat ... 20EFI.html
