Roller fuel pump pushrod
cgarb
Post by cgarb »
Anyone ever use a Pro Cam or comp roller fuel pump pushrod? I have a billet cam in a sbc and ran a bronze tipped pushrod and it mushroomed the bronze end last year. Seems like an small bearing on the end, Looking at that maybe or a composite pushrod to try instead. Any input will be appreciated.
77cruiser
Re: Roller fuel pump pushrod
Post by 77cruiser »
I used a Howards composite for about 3000 miles,with no issues, but then I went in tank electric.
Jim
BOOT
Post by BOOT »
I didn't get that ^^^^^ long out of my composite
travis
Post by travis »
Comp used to make a roller tipped FP pushrod. Never tried one, but bronze just doesn’t seem to last long
induction apprentice
Post by induction apprentice »
I wonder why they cant make a mellenite tipped pushrod for roller stuff?
steve cowan
Post by steve cowan »
Been running composite pushrod for a couple of years,500 hp 383 sbc
Holley 200gph mechanical pump
Street /strip car 11.0s @3400 pounds
Just pulled engine for freshen
Fuel pump pushrod looking brand new, cam is good,
When I first bought the composite I also purchased a pushrod with the little wheel deal, I have never used that one, I cannot see how that thing will survive lol
Just for the record I also use composite distributor gear with adjustable sleeve on MSD billet distributior with surface rust on the magnetic pick up the same as everyone else
Steve C
steve c
"Pretty don't make power"
steve cowan wrote: Fri Apr 13, 2018 5:01 am Been running composite pushrod for a couple of years,500 hp 383 sbc
Steve C
Lol... Spot on with the msd patented un protected reluctor. Wt... is that all about all these years? lol
BOOT
Post by BOOT »
induction apprentice wrote: Fri Apr 13, 2018 12:35 am I wonder why they cant make a mellenite tipped pushrod for roller stuff?
I think stock ones are, but they are also heavy compared to the hollow ones.
77cruiser
Post by 77cruiser »
BOOT wrote: Fri Apr 13, 2018 12:14 am I didn't get that ^^^^^ long out of my composite
What happened to it?
Jim
BOOT
Post by BOOT »
77cruiser wrote: Fri Apr 13, 2018 9:48 am
It wore a lot in a short time
ClassicComp
Post by ClassicComp »
Any problems using the ARP pump pushrods?
results speak for themselves
racear2865
Post by racear2865 »
I guess Im lost here. I use quite a few composite fuel pump rods with bronze tips both in drag cars and circle wagon cars. All are used with billet cams and I put in a lathe and use jewelers rouge to polish up and peck on wood, never lost one yet. But Im going to bet, it didnt mushroom from wear. I would say you are floating the rod and hammering the end flat. Go as light a rod as you can get. I did try a steel rod with bronze end and beat the heck out of it. Went composite with bronze tip and another fuel pump
reed
BOOT
Post by BOOT »
racear2865 wrote: Sat Apr 14, 2018 11:52 am I guess Im lost here. I use quite a few composite fuel pump rods with bronze tips both in drag cars and circle wagon cars. All are used with billet cams and I put in a lathe and use jewelers rouge to polish up and peck on wood, never lost one yet. But Im going to bet, it didnt mushroom from wear. I would say you are floating the rod and hammering the end flat. Go as light a rod as you can get. I did try a steel rod with bronze end and beat the heck out of it. Went composite with bronze tip and another fuel pump
reed
The composite people are talking bout is the entirely plastic one(I know it's not normal plastic but some high tech junk).
77cruiser
Post by 77cruiser »
Jim
racear2865
nope not the one I use. Its is composite with a bronze tip (not brass). when I get back in shop Monday and my damn old mind dont furgit, Ill take a picture. Got one on dyno now.
reed
