Page 1 of 1
Wiseco piston ring compressor
Posted: Wed Apr 11, 2018 11:30 am
by Matt80
Hi, never had one in my hand, so can't imagine if it would be doable to enlarge a 3.385" piston ring compressor to 3.395" on a lathe as they do have a teflon coating
Re: Wiseco piston ring compressor
Posted: Wed Apr 11, 2018 12:24 pm
by pamotorman
i machined my own ring compressors out of steel and used no coating. if they are made from aluminum that may be a problem as it is softer than steel
Posted: Wed Apr 11, 2018 12:34 pm
by Matt80
pamotorman wrote: ↑Wed Apr 11, 2018 12:24 pm
Ah, true. Can you please tell me the lenght, top diameter and taper angle you used on yours?
Posted: Wed Apr 11, 2018 1:18 pm
by pamotorman
Matt80 wrote: ↑Wed Apr 11, 2018 12:34 pm
i done that many years ago so i have no idea. i got rid of all those tools i had when i retired 22 years ago. sorry i can not help
Posted: Wed Apr 11, 2018 1:21 pm
by Matt80
pamotorman wrote: ↑Wed Apr 11, 2018 1:18 pm
Ok thanks
Posted: Wed Apr 11, 2018 1:56 pm
by MadBill
Most compressor rings have a short parallel bore at the bottom of the taper, but I don't see that it's presence is critical. Therefore, you should be able to chuck it up in a lathe and face off the small end until the exit diameter 'grows' to the desired size. If you know the taper angle, a little finger work with the trig functions on a calculator will even tell you how far to go the achieve the required diameter.
Posted: Wed Apr 11, 2018 2:06 pm
by Matt80
MadBill wrote: ↑Wed Apr 11, 2018 1:56 pm
Sure, thanks
Just wanted to know, if possible, the taper angle and the increase in percentage at the top diameter used on the Wiseco/ARP/etc ones
Posted: Wed Apr 11, 2018 2:21 pm
by rfast racing
My 4.030 tapered ring compressor starts out at a .250 thick piece of material 1.800 in long the taper is 8 degrees .300 from the end is the bore size so the taper is only 1.5 in long
Posted: Wed Apr 11, 2018 2:42 pm
by Matt80
rfast racing wrote: ↑Wed Apr 11, 2018 2:21 pm
Thanks!
