Potential of ported Edelbrock Performer RPM’s 6025’s
user-17438
Re: Potential of ported Edelbrock Performer RPM’s 6025’s
Post by user-17438 » Tue Apr 10, 2018 10:22 am
groberts101 wrote:
Tue Apr 10, 2018 10:16 am
MTENGINES wrote:
Tue Apr 10, 2018 10:11 am
No doubt.
What's with the big gash, if that's what it is?.. in the fire deck above the intake valve?
its a sigh groove..lol
Why do you say that? Because you "sigh" everytime yiu see one? LOL
yup.lol
Newold1
Post by Newold1 » Tue Apr 10, 2018 10:48 am
Obviously don't know what part of the country you are in but most likely there is a good cylinder head man or shop with good performance cylinder head abilities around you.
As others here have said, those heads need some pretty important work and parts, so put together an idea (budget) of what you CAN spend and see if its worthwhile to get into all they really need. With the intake at that exposure in the head they have been milled a lot and maybe even angle milled. If that gash in the deck is real then they are going to need additional milling and if that's the case they are just about junk in my opinion. If you are building something where you need a particular cfm flow then also make sure they are flow benched to make sure they what additional porting they may need and you should cc the ports and chambers to see where they are at now.
I would not advise just using them on a engine without some real careful look over!
Sometimes parts like these can be more expensive with all the rework needed than it would cost to buy a ready to run pair that can perform up to your needs. JMO
thomas butt
Post by thomas butt » Tue Apr 10, 2018 11:33 am
Sounds good. Thanks to all for the good advice. I might just sell them especially if they need work on the deck and other places. I am an amateur enthusiast and don’t know that much about head work.
mag2555
Post by mag2555 » Tue Apr 10, 2018 12:09 pm
Looking at that chamber again promp's me to think that the intake seat was re-cut for a 2.08" valve.
CGT
Post by CGT » Tue Apr 10, 2018 12:16 pm
Those heads appear to have had a terrible former life or two.
"How or Y do you think I get all this $hit, I read all of you all builds and desktop dyno them with all the correct info and I've got your build."
cab0154
Post by cab0154 » Tue Apr 10, 2018 2:14 pm
what happened to porting the cleveland heads and building that?
thomas butt
Post by thomas butt » Tue Apr 10, 2018 2:27 pm
There on the back burner. I still have them but am not sure o want to mess with the heads because the whole M code engine, intake to pan, is all stamp dated within a week of each other so might sell to a restorer of a 70 mustang or Torino. They’re all 12/69 date.
I’ve got both a set of N351 & n352s to make a fast motor out of. I haven’t done much of anything though. Been busy buying foxbody coupes the last two years.
NXBOY
Post by NXBOY » Tue Apr 10, 2018 4:52 pm
I agree after zooming in, can clearly see two angle, inner one looks like a 45 and out like a 30-35. If thats the case it won't fit and have enough working clearance, that might be why 2.02 are in it instead. Pictures can lie though. Theses heads work good, just dont do very much at overall. .Bigger is not better with these heads. ButChamber smoothing and sizing bowl to 90 percent and making the Short turn like will be important as opening bowl will change/hurt SSR if not rolled at least like factory. A perfect round SSR will get ya in the 250 cfm pretty easy but fall at .550 lift. Pinch is big enough , dont open much if you do. There springs are weak from factory, get some new ones for sure. Looks like the gash just missed the fire ring. Take apart and have someone check guides/seats and port work. might be better then it looks. I wouldn't guess.
cab0154
Post by cab0154 » Wed Apr 11, 2018 1:45 pm
I understand. 20 years ago when I hurt a couple pistons in my 93 I bought an early 302 block and crank from a friends dad who was a big ford guy. It was a virgin bore 1970 boss 302 block and matching forged crank. I was going to use it for a performance build. But when I looked up the serial numbers on it I found that the car was in missouri. So I offered it to the guy who had the car. He was happy to get it. I dont have any regrets because I didnt throw a rod through very rare block and at this point I have a block that makes the mains in the original boss 302 block look like origami. The profit I made on it wasnt bad either.
Not to mention that the N351 can make power.
