Teflon Intake Gaskets---where to buy???
GM-DR
Post by GM-DR » Sat Apr 07, 2018 2:46 pm
A few years ago I bought .093 thick Teflon Intake Gaskets for my Drag Race 350 Chevy-I am still using them today-appx 10 intake manifold installs and re-installs-----------Now I am building another engine and I need another set, but I cant remember where I bought them ??? Any Help would be appreciated Thanks Greg :?:
dfarr67
Re: Teflon Intake Gaskets---where to buy???
Post by dfarr67 » Sat Apr 07, 2018 7:07 pm
Kevin Johnson
Post by Kevin Johnson » Sun Apr 08, 2018 10:20 am
Thank you for the plug but any water jet shop should be able to cut them. Attach the Teflon sheet to a sacrificial substrate as it is not rigid. I think you would want to just use water, not the grit as well. The gentleman across the street from me had a Calypso WJ and I observed that when starting a cut the grit was not finely focused. You would not want that excess grit spray to embed in the Teflon.
GM-DR
Post by GM-DR » Fri Sep 21, 2018 2:14 pm
Ok for those of you that might be interested I found the Gasket supplier Nagy Performance Systems- but can't find their web site
427dart
Post by 427dart » Fri Sep 21, 2018 2:37 pm
Sounds like a great gasket idea and wonder why the big name gasket makers haven't picked up on it?
So you use these with no sealer on either side?
Kevin Johnson
Post by Kevin Johnson » Fri Sep 21, 2018 2:40 pm
http://nowearracing.com/intakegaskets.html
From 2011:
https://web.archive.org/web/20110210214 ... stems.com/
