Also the internal orifice on my bench is not a calibrated orifice. It is sized depending on the max flow I expect to get at 100% of the scale which is 36 inches long. I use the PTS calculator to size the internal orifice so it will supply 16" H2o at a rating slightly above the max flow I calibrate to at 100 percent of the scale. The critical part is the calibration orifice that is taped down the settling chamber in my case it is a 112CFM 1.25 diameter sharp edged orifice. The flow at 28" is 112CFM and I adjust the manometer angle to get it to 100% of the scale at 28" of depression. The most these little heads will flow is slightly below 100 CFM.
